1. pc will restart itself, with no warning, for no reason
2. pc will freeze, showing a bunch of blurry, orange and brown blurry horizontal lines
pc specs:
psu: XION Supernova XON-600F14R-201 600W ATX12V
mobo: MSI DKA790GX Platinum
cpu: AMD Phenom 8450
ram: OCZ Platinum 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500)
HD: Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s
OS: Vista 64 bit home basic
now, it doesnt always restart itself or freeze, it seems very random, ive been able to use it nontstop for 3+ hours as of now, but just last night, it froze 3+ times in a matter of an hour, and before that it restarted itself 2 times in an hour...any ideas? work your magic
the pc has been running fine for about 15 hours now, no phantom restarts, no hanging or errors, even played a little cs:s.
i went through the build again to make sure everything looked right to me, and i noticed i had put my ram in slots 2 & 3, instead of 0 & 1, like it said in the manual, so i changed that...maybe that was the problem?
i also un-installed dual core center, because the one time i used it, my pc froze and i had to restart it, and it was a startup program, maybe that was the issue? who knows...
