What power supply should I get?
Hello,
I am going to build a computer with these components:
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz
4GB (2x2GB) DDR2 SDRAM
EVGA GeForce 9800 GTX+
7200 RPM SATA 3.0Gb/s Hard Drive
DVD-RW drive
Also, I will be overclocking.
the wishlist on newegg can be viewed here:
https://secure.newegg.com/WishList/MySavedWishDetail.aspx?ID=13560007
As for the case and the mobo, I haven't totally decided. I'll probably change the case, and probably not the mobo. Anyway, I'm not sure about what psu to get for this. The newegg power supply calculator tells me I should get a 585W psu, but after reading some posts here it seems to me as if that's high. So what psu should I get?
2 answers Last reply
More about what power supply
  1. No point in getting a SLI motherboard if you're not planning to add another 9800GT+ in the future, so i'd go with this 650w Antec Earthwatts 650 for $50 with free shipping.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
    review of that PSU from www.jonnyguru.com
    http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=110
  2. I went with the Earthwatts 650 as you suggested. Also, I'm going to get a different motherboard because I'm not planning on SLI. Thank you for your help!
Power Supplies Components Product
