Storm Scout Case Question
Hey all, I was wondering if anyone has swapped the stock fans that came with their Storm Scout for a different bunch 120 mm fans. I'm getting one for sure for the cases side and there is a deal for getting multiple Scythe 120mm fans... So would it be worth swapping it out?
1 answer Last reply
More about storm scout case question
  1. Unless you ate trying to reduce noise or put in higher CFM fans, there really is no point to swapping out the fans on that case.
Cases Storage
