Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Decisions, Decisions....Help?
Forum Homebuilt Systems : General Homebuilt - Decisions, Decisions....Help?
Which upgrade to get?
Warning, if you click on "see results", you won't be able to vote
Hey guys i just wanted some input as to which you would rather prefer?
look at my system configuration and tell me which upgrade you would rather get first?
a second 9800gt for sli (http://www.newegg.com/Product/Product.aspx?Item=N82E16814130377)
or a new ASrock 750a sli mobo (http://www.newegg.com/Product/Product.aspx?Item=N82E16813157128)
im getting the 5400+ black edition with either purchase.
also any input on what else would help make my rig more AM2+ ready (hoping AMD steps up their game so i can get a faster AM3 chip and just use my old DDr2 RAM)?
------------------------------ | Athlon x2 5000+ @ 3.2 | Biostar Tforce 570 sli | Sli 9800GT | 2x 512mb Corsair xms ddr2-800 | 2x 512mb Crucial Tracers ddr-800 | Antec 900 | 22" HannSpree | Creative Itrigue 3000 | PS triple
Sponsored Links
A mobo upgrade is point-blank cuz it will NOT boost your FPS by 10/20/100, etc. It will perform more or less the same as your current one with the same cpu & gpu. A gpu upgrade will DEFO boost your FPS.
The T-Force is an overclocker capable of pushing AM2+ BE's. Keep the mobo. Save up & wait for AM3.
It depends on your upgrade goal.
Reply to auscanzukus
i would say the CPU will be more of a limitation when a more powerful GPU being put in.
Reply to iluvgillgill
thanks guys i got me the athlon x2 5000+ BE and the second 9800gt.
Do you think it will bottleneck much?
Reply to teh_boxzor
i would say yes. 2 GPU is really data hungry. people usually OC their Intel to 3.4Ghz and above. so clock for clock AMD will need about 3.6Ghz to do the good job. i mean test it out with Fraps see how much fps you will gain when you OC from stock to say 3.2ghz.
fosho thanks for all your help.
Reply to teh_boxzor
There are 1155 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
