Tom's Hardware > Forum > Homebuilt Systems > New System Build > Problem with new build
Hi,
I just built my system and I am having problems with the screen resolution. The system boots up fine, but the screen resolution will not go above 640x480 and 4bit color (the option in settings is not even there). I tried a 2nd monitor and get the same problem. Everything is new except for the monitor. Could my power supply not be sufficient? Driver problem? Any help is greatly appreciated.
Antec EA430
GA-Ep35-DS3l
E7200
Arctic FP7
PNY 8800GT
7200.11 500gb HD
2 gig (1x2) G.Skill
Lite-on DVD
Proview 19" CRT monitor
Sponsored Links
Have you installed the latest drivers from nVidia? I recommend using drivercleaner to remove those bad drivers. Download the latest drivers for the 8800GT. Then download the drivers for your monitor (not really needed, but every little bit helps).
also make sure your motherboard drivers are up to date, as well as the BIOS.
Edit, What OS are you using? Also what power supply?
Message edited by IH8U on 09-05-2008 at 09:46:31 PM
Reply to IH8U
Sounds like a driver issue to me off the bat. Have you tried downloading a new driver?
Reply to kamel5547
did you install all the drivers in the system?check properties>Hardware>Device Manager to see if there is any uninstall hardware.
Reply to iluvgillgill
- 0 +
Thanks,
I am using XP Prof. 32 bit.
I used the MB driver cd that came with it as well as the Nvidia driver cd for the graphics card. My power supply came with the case, Antec NSK6580 with a 430W PSU.
Thank you
Reply to Chawncy
- 0 +
Hmm,
I uninstalled all graphics and monitor drivers in device manager, shut down the system and restarted with the Nvidia disk in. Everything loaded, pnp monitor driver loaded and resolution was fine, but several minutes later the screened went black and came back on with the old 640x480 4bit?
Reply to Chawncy
did it gave any warning saying anything wrong?
- 0 +
It seems that I have an old version of Windows (Svc PK 1). As soon as windows downloaded and updated it corrected the problem.
Thanks to all who took the time.
Reply to Chawncy
There are 1133 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
