When I start the computer everything starts up all fans the hd the disk drive ect.
The cpu fan only starts up when it is another slot the sys_fan in this case the weird thing is the cpu_fan slot has 4 pins and the sys_fan slot only has three.
I have resetted the video card, memory, cpu fan etc.
I have taken out the bios battery waited and then put back in.
I've tried everything else have been able to find on the internet short of putting a jumper on the cpu_fan slot because someone said the mobo wouldn't start up if nothing was plugged into that slot. I didn't try it because i do not have a jumper.
I'm really out of ideas other than taking it into a shop.
Any help would be greatly appreciated thank you.
I tried putting the cpu plug back into the cpu_fan. I made sure the 4 pin from the psu to the mobo was connected.
Everything turns on except for the cpu fan which only gives a slight twitch but nothing shows up on either monitor still.
I've tried taking it out and reassembling same symptoms.
I assembled the it outside of the case on top a phone book still had the same symptoms.
I have the brass standoffs in the right places.
I tried a spare psu and all i got was a loud whine.
How would i know if it was the mobo or the cpu?
