Tom's Hardware > Forum > Homebuilt Systems > New System Build > HELP!! New build will not post! I need some advice!
Forum Homebuilt Systems : New System Build - HELP!! New build will not post! I need some advice!
I am currently building a new budget system using
-Foxconn M61PMX Motherboard
-AMD Athlon 64 X2 5000+ Brisbane 2.6GHz 2 x 512KB L2 Cache Socket AM2 65W Dual-Core Processor
- 2 GB G.Skill DDR2 800 memory
- 300 watt rosewill PS
When I push the power button the fans will start for about a half revolution and then nothing will work. When I push the button again the fans won't even start again. I have tested the power supply and even tried a different one in it and it still does the same thing. I have tested the processor, memory, and even replaced the MB. This is by no means my first build but I have never encountered this problem before. I am at a loss, please help!
Message edited by old pc lover on 09-05-2008 at 10:39:25 PM
Sponsored Links
the only real tip thats in mind is check the number of spacers on the motherboard tray
you could have a short
Reply to eklipz330
I'll check that and get back to you. Thanks for the quick reply.
Reply to old pc lover
Did you connect power to both the 24 pin connector and the 4 pin connector near the CPU?
Did you only install/use standoffs at the correct places corresponding to the holes in the motherboard?
Did you re-check the connections between the case and MB?
Reply to Proximon
looks its mobo protecting itself.make sure all standoff is installed.
Reply to iluvgillgill
I hate it when this happens. Here's a few things that i've run into. Short in case. Faulty power button on case. ^ short on mobo tray. I usually take a deep breath, pull everything out, clean and search for anything that looks wrong (bad solder, caps etc.) step by step put it all back in. 1 stick RAM. Give it another shot. Good luck, we've all been there, it sucks.
Reply to dirtmountain
That was it! I had a MB Standoff in the wrong place. I hate when I do that sort of thing. I feel a little dumb for not thinking of it. Thanks to everyone who helped!!!
sigh.....................well done:P
There are 1142 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
