alright. i have 4GB of ram.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
i took a look at Cpu-z and it says my DRAM frequency is around 400MHZ. and i have DDR2 800 ram.
is it running at half speed?
thanks for the help. i don't know much about ram and i just posted this to be sure that therei s no problems with it.
THANKS.
THANKS.
