Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > quiet + dual monitor
Forum Graphic & Displays : Graphics Cards - quiet + dual monitor
please help!
I need an ATI crossfire card for my digital audio pc/ general home use.
It needs to be quiet (quiet fan or fanless) and support dual monitors
I do some gaming but not much
mb- p5q-deluxe
cpu- intel q9550
psu- corsair 520HX
ram- 4gb (2x2gb) g.skill ddr2 800
hd- 2 x 320gb western digital 7200 16cache sata2
case-p182
thanks
Message edited by nate313 on 09-30-2008 at 09:04:07 PM
Sponsored Links
should be able to find a 46XX card for cheap. I do recall seeing a passively cooled one on newegg.
------------------------------ If you don't know what OS/2 is, you don't understand.
Reply to rockbyter
I'd agree that a HD4670 would probably be your best bet, all out of stock though at newegg. Didn't see a passively cooled one, but they should be very quiet with their low heat sig. None supply the crossfire bridge, that's going to be an extra.
http://www.newegg.com/Product/Prod [...] 6814127383
may be available at www.buy.com $87
http://www.buy.com/prod/radeon-467 [...] 53740.html
Reply to dirtmountain
+1 to the 46xx crowd. The 4670 will let you game some though, so you might want to set your sight on that one :P
Now, if you want a quiet overall system, watch/hear carefully the Case fans. They usually are the loudiest component around, after the CPU fan under load :P
Esop!
Reply to Yuka
There are 1250 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
