Tom's Hardware > Forum > Homebuilt Systems > New System Build > Decided on these parts, need reassurance.
Forum Homebuilt Systems : New System Build - Decided on these parts, need reassurance.
SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD Burner
http://www.newegg.com/Product/Prod [...] 6827151171
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Prod [...] 6822136218
GIGABYTE GA-MA78GPM-DS2H AM2+/AM2 AMD 780G HDMI Micro ATX AMD Motherboard
http://www.newegg.com/Product/Prod [...] 6813128341
SAPPHIRE 100247L Radeon HD 4870 512MB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
http://www.newegg.com/Product/Prod [...] 6814102769
Antec earthwatts EA500 500W ATX12V v2.0 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Prod [...] 6817371007
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Prod [...] 6820231122
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor
http://www.newegg.com/Product/Prod [...] 6819115017
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
http://www.newegg.com/Product/Prod [...] 6835186134
Microsoft Windows Vista 64-Bit Home Basic for System Builders Single Pack DVD
http://www.newegg.com/Product/Prod [...] 6832116200
Antec Nine Hundred Steel ATX Mid Tower Computer Case
http://www.buy.com/retail/product. [...] 79&loc=101
Anything I should change? Any criticism on it is greatly wanted.
Sponsored Links
Vista Home Premium 64bit is only $10 more, you should consider it.
http://www.newegg.com/Product/Prod [...] 6832116488
Reply to glenngjp
Oh, and that mobo is for AMD CPU's, your q6600 wont fit in it.
I hear http://www.newegg.com/Product/Prod [...] 6813131329 or http://www.newegg.com/Product/Prod [...] 6813131333 are good choices for about the same price.
Message edited by glenngjp on 09-06-2008 at 03:04:39 AM
Reply to glenngjp
- 0 +
CPU-Motherboard mismatch........
You're looking to build a gaming rig?
Reply to WR2
Yeah going for a gaming pc that wont destroy my pocket.
Following the posters above and getting the home premium, and choosing http://www.newegg.com/Product/Prod [...] 6813131333
Really glad I posted lol
Reply to pickelweasel
- 0 +
Yes - that Q6600 will be much happier in that ASUS P5Q SE P45 motherboard.
Im a little concerned that the Q6600 OC'd and the 4870 OC'd will push the Antec EA500 a little too hard. The Q6600 can suck a lot of power when OC'ing.
How about the OCZ GameXStream 600W? It's only $10 more but has free shipping so the amount charged on your credit card should be about the same. And it does have a $30 rebate.
The NewEgg site says it has 2 6pin PCI-e connector but the OCZ website says it has 1 6pin and 1 6+2pin (8pin) connectors.
The rest looks good.
Reply to WR2
^ agree with WR2 about the OCZ Steathstream. Good changes. Never hurts to doublecheck a build.
Reply to dirtmountain
There are 1291 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
