Make sure your "Router" has DHCP enabled. DHCP will assign your laptop/PC an IP address however the router will still allow you to connect to the router without having DHCP enabled but you will receive the "limited access" error.
Another thing to check is if your wireless connection has a static ip address assigned to it in a different range from that whats specified in the router.
