Hi i'm building a gaming pc and this will be my second system that I have built and I need to know if each part is worth it and has the best performance.
What is your total over all budget? Anything already on hand that you want to use?
What size monitor/resolution will you be using? What games are you looking at playing?
I can tell you the WD Raptor 74 doesnt match the rest of the parts. Put in the WD Velociraptor 300GB HDD instead.
Drop the $$ if you got it. Although I would rather build 2 machines around $2k over a couple of years. You'd always have a good machine but you aren't bleeding money. But then again if you like throwing money around go for it. Wasn't there an article that shows standard SLI beating 3-way SLI most of the time? I'm too lazy to look it up though.........
I wouldn't bother with the sound card. If you want an audio quality upgrade, or some feature like software bass management, look into a card from Auzentech or HT Omega. Otherwise, just stick with the onboard sound.
i agree with wr2, the velociraptor is much faster, and are you planning on multiple monitors in the future? or a larger monitor, if not tri sli is a little excessive, also the ddr3 is not a good idea unless you plan to migrate it to a system in the future that utilizes tri channel, in which case, but a cheaper system that is good quality that you can sell later and save some cash
I will switch the the hard drives and I was deciding between 2 4870 x2's and 3 280 gtx's but saw an article that 3 280s beat the 2 4870 x2 in every game fps wise. And is the on-board sound card that good? I am pretty much just planning to use the best computer I can until I turn 18 in a year and a half.
I think you want to check out some more benchmarks before you make up your mind and start spending.
Is there a particular game you're most interested in? If yes, find out if ATI or Nvidia runs that game best.
I think it would be smart to look at a 27" 1920x1200 LCD monitor and thinking about 2 graphics cards instead of a 24" LCD and 3 GPUs.
Also the Intel Core 2 Quad 3.0Ghz Q9650 is $900 less than the 3.2Ghz QX9770. Most games are GPU limited before they are CPU limited and you end up with charts that look like this: (just 1 video card used here but the concept still applies for 2 or 3 GPU rigs)
sorry to bust ur bubble mate, but if its gaming ur better off with the Core 2 Duo E8500. Yeah really. Save 1000 bucks as well, almost.
Also just go for the Xfi extrme gamer.
