Hi
Ive just built a new computer for a friend:
Q6600 G0
Freezer 7 pro
2Gb OCZ RAM
650I ultra mobo
Generic hdd and optical dvd drive
580W Hiper PSU
So I boot it, lights fans everything starts, but no image on the screen. I get constant long beeps from the mobo speaker. However I did manage to get a monitor picture once (the BIOS) but the keyboard wouldnt work so I restarted and it went back to the same thing.
Any ideas?
Sponsored Links
Try each stick of ram in each slot, up vdimm in bios on post, then install the other stick.
Reply to auscanzukus
- 0 +
Try reseating your video card or cards, make sure they are completely in the PCI-e slot, do the same with each stick of ram.
quotemsg=1848392,1,343602]Hi
Q6600 G0
Freezer 7 pro
2Gb OCZ RAM
650I ultra mobo
580W Hiper PSU
Any ideas?[/quotemsg]
------------------------------ X58 Classified
965 Extreme at 4GHz 12TEC Boreas
2- GTX 295s
12 Gbs CSX 2000MHz
Reply to stan116
Ok got it all working great, with CPU temps at 26C idle which im pretty happy with. It turned out to be the RAM, thanks aus. I changed the sticks into different slots (2,3) however if theyre in 0 and or 1 then my comp doesnt post, just long beeps. Any idea why this may be? I tried different RAM but I get the same thing...
Reply to falcodakrzz
Some boards have slightly different ram channels. i.e. channel 0/1 is good for generic ram while channel 1/2 is good for high-volt ram. It's not the same for all boards. Just some.
Tom's Hardware > Forum > Homebuilt Systems > New System Build > New build help
There are 1165 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
