Tom's Hardware > Forum > Motherboards & Memory > Memory > 2+1 gb in xp.problem?
Forum Motherboards & Memory : Memory - 2+1 gb in xp.problem?
have a two slot memory on mobo and i put 3 gb ....i heard that it may be a problem ....less speed than if i had only 2gb of ram..thank's
Sponsored Links
Most newer motherboards have 4 memory slots. The memory slots are different colors if the MB supports dual channel. Each channel needs to match in size to retain this functionality but I don't think you would lose much performance if they didn't. So if you currently have 2GB and each stick is in a different color then you aren't utilizing dual channel anyway. If you want to add a third GB and retain dual channel capability you need to put in two 512MB modules in the second channel (color). I hope this helps and maybe someone can correct me if I am wrong.
Reply to DeadRam
i have only 2 ram slots
Reply to aristita
There are 1217 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
