Wire managment help
Forum Homebuilt Systems : General Homebuilt - Wire managment help
Ok so i built my system 3 weeks ago and i just ordered a new heatsink to replace the stock. I just looked into the case and saw how bad my wire job was. I was wondering if you guys have any advice for me because I want my airflow to be a bit better.
pictures
http://i82.photobucket.com/albums/j254/bnbkiller/IMG_1918.jpg
http://i82.photobucket.com/albums/j254/bnbkiller/IMG_1919.jpg
http://i82.photobucket.com/albums/j254/bnbkiller/IMG_1920.jpg
Sponsored Links
well, for me, im guessing from the looks of it your using an antec 900, and a corsair 750tx psu, which im using both, i just shoved my extra cables in one of the 3 inch bays
edit: but we could both us a better solution then the one i have
Message edited by marshmellow1991 on 09-07-2008 at 05:22:32 AM
Reply to marshmellow1991
This should be no problem.. You just need to tie rap everything into a bundle and use some wire holders that stick to the case (i am a electrican and i call them sticky backs) to hold everything in a nice neat place. then roll unused power supply cables up at bottom of case again using tie raps.
Reply to PCnut
I must say, the annoying thing about this psu, is that on a single cable you got like 5 connectors, which takes up a fair bit of space themselfs
move it all behind the mobo tray... take advantage of any holes going there.
You can use hot glue as a means to hold wires.
Take your time.
Here is mine... I think I did a fair job
http://i201.photobucket.com/albums/aa129/xringx/007-1.jpg
------------------------------ Q6600@3.6(9x400)Lapped Abit IX38QuadGT,TRUE 120 Lapped,Vista Ultimate 64bit,Gigabyte HD 3870 OC'd to 860/2250 w/ Zalman Fan,4x2GB G.Skill PI-Black,CM690 w/ 5x140m 3x120m fans,Idle 28c load 42c-Corsair HX620w
Reply to xringx
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Wire managment help
There are 662 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
