Well I'm a new at this sort of thing, and I'm looking to make a gaming computer for about $1000, to $2000 dollars. I've looked into some stuff, and figured out I'm pretty much lost with what seems to be a lot of parts that seem to be exactly the same, any good help with a system?
You can make an easy start of it by looking over some suggest builds over @ TechReport: TR's back-to-school system guide Beyond that it's just a matter of looking other forum posts and seeing the recommendations and discussions made there by people looking to build gaming systems in the price range similar to yours. You'll notice lots of opinions - don't let that bother you - there is no single "perfect system".
If you want to learn even more you'll be spending some time reading reviews at some of the tech review websites like;
Anandtech - ExtremeTech - TechReport - THG
When you have a list of parts you feel good about you can post your system list here and ask for opinions and alternatives.
Good build ~$1500 i think:
P5Q Deluxe mobo
Q9550 cpu
4 gigs of 800/1000/1066 ram
Nvidia 9800GX2 (older but has a great $/performance now)
WD 640AAKS
Antec 900/1200 (if u want full tower)
Thermaltake 850 (or other good PSU make sure it has an 8 pin for GX2)
Cpu cooler- Xigmatek 1283, Sunbeam Core Contact Freezer, Thermalright 120 Extreme (only if ull lap it)
Its a good build and can be fined tuned to ur needs
------------------------------Antec 1200|Antec Signature 850w|Asus Maximus II Formula|Q9650|4GB Dominator 1066|EVGA 9800GX2
Reply to Silverion77
Look over the recommendations by lunyone as a good recommendation for a $1000 base system. Add a keyboard, mouse, speakers and nice monitor and you have a great $1500 gaming PC.
The most important component for gaming is the VGA card. Get the best one that you feel comfortable buying. The GTX280 is a fine choice, and will be able to play anything out there very well. It should cost about $400. Some go higher because they are factory overclocked to the tune of about 10%. That premium does not seem worth it to me. Others are more expensive because they have factory installed water cooling. Also not worth it to me.
The 4870X2 is the new card on the block. In general, it is more capable than the GTX280, but it comes at a premium price of about $550. Is it worth it to you?
Remember, that these cutting edge cards will be somewhat dated in a year.
At the level of the E8500 or Q6600, the vga card is much more important for gaming than the cpu.
At that level, overclocking is good for bragging, but it will not net you as much increase
in FPS as a better vga card will. Today, very few games can make use of more than two cores.
Flight simulator X is an exception. It is not a trivial matter to code multi threaded programs,
and game vendors will not sell too many games that require quads to run.
I don't see this changing in the next couple of years.
Net: E8500 for the increased clock speed.
Most oem coolers will do the job, and keep the noise low. Xigmatek os very popular, and priced well http://www.newegg.com/Product/Prod [...] 6835233003 Do get the oppptional backplate to avoid thise tricky push pin mounts.
There is no need for a premium priced motherboard unless you are planning on dual vga cards. You should be able to get a Nice P35 or P45 motherboard from Asus or Gigabyte for <$100.
Is there a need for two cd/dvd drives? A dvd burner will do everything. Samsung makes a quiet one.
I happen to like fast hard drives, and the raptor is good. The velociraptor is even better, but it DOES make a difference. I like the strategy of a fast small system drive and a slower large drive for storage and backups.
For ram, get 4gb in a 2x2gb matched kit. It preserves your option to upgrade to 8gb, and it is easier to overclock with just 2 sticks.
DDR2-800 from a quality vendor is fine. Faster is not much worth it. Think 1-2% inframe rates vs. synthetic benchmarks.
Vista home premium-64 is good. Do you qualify for an academic license?
PC Power & Cooling S75QB 750W ATX12V / EPS12V SLI NVIDIA SLI Certified (Dual 8800 GTX and below) CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
You can leave it like that, switch the HD 4870 for an HD 4870 X2, or just drop a second HD 4870 down the road.
+1
I like your inclusion of accessories, but would hesitate to recommend an $80 keyboard. The Death Adder is the best mouse I have ever owned(out of MX518, G5, and Diamondback)
Yeah missed a headset, didn't want to throw in one too expensive, since I'm careful about audio. I like the Lycosa but I'd also recommend the Saitek Eclipse/Eclipse II if the Lycosa feels too expensive.
