Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > where to buy 2 x 6pin PCIe power leads from ?
Forum Graphic & Displays : Graphics Cards - where to buy 2 x 6pin PCIe power leads from ?
Sponsored Links
LOGISYS AD201 12v Molex to 12V 6Pin Adapter
If you need these then there is a very good chance your PSU is not able to power the graphics card.
What is your PSU model and what are your PC specs?
Message edited by Zorg on 10-02-2008 at 05:12:54 PM
Reply to Zorg
- 0 +
I cant use the convertors as XFX specifically state not to use them. I'm going from a 8800GTX to a 650W Tagan power supply but i'll be damned if i can find anywhere which sell the 6pin PCIe to 5pin power leads to do this
Reply to krest
- 0 +
What are 5 pin power leads?
The molex to pcie6pin should work fine.
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
There are 504 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
