Hi yall! I'm wondering if you guys could help me out. I can't quite remember how the Bernstein Audio is hooked up after my cousin disassembled it (It was pre-assembled). My PC was taken apart and put back together cause Vista previously crashed and we thought it was a hardware problem.
Anyways, I hooked the Audio Module cable from the board to the the card, and also the AC97. After that, I installed the proper audio drivers from Realtek. I get sound using the the Realtek Speaker test from my rear-left, rear-right, and center, but none on the front left and right speakers. Therefore no sound at all when I play any type of files. That didn't work so I disconnected the front audio cable and hooked up the one that said HDAudio or something, and I didn't get anything at all-my sound devices just show HDMI Audio because of my ATI 3870. Therefore I reconnected the the AC97, tried the other separate wires (Don't really have a clue on these cables) and I'm just all frustrated. And in the DFI booklet it really doen't show any type of way to connect it. Am I doing something wrong?
The only way I'm getting sound now is if I use AUX Cable out from the headphone jack (from top of CM 690 case) to the Audio In on my Logitech X540, and I really don't want that extra wire. Does anyone else with the same MB have this problem? because I even googled for help and only found another guy who had a similar problembut didn't really help too much! Can anyone help? I'd really appreciate it.
Anyways link here to my DFI X48 specs:
http://www.dfi.com.tw/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?itemId=532&downloadFlag=false&action=e&windowstate=normal&mode=view
