Tom's Hardware > Forum > General Networking > Network General Discussions > 2 Wire Router, how to Firewall wired connections from Wireless?
Forum General Networking : Network General Discussions - 2 Wire Router, how to Firewall wired connections from Wireless?
Hello again all,
My business network is all setup and hardwired through a Switch (changing from 2 HUBs to a switch shortly).
I'm accesing the internet via an AT&T 2-wire router.
What I want to do is setup the router so that all hardwired network is firewalled... and I can set the Router to Wireless so Customers can use WiFi but still not be able to see or access the business network.
Thoughts?
Thanks all!
Sponsored Links
You need a separate wireless router with it's own subnet to segregate your customer network from your business one.
Grumpy
Reply to Grumpy9117
Ok, so I keep the Router I have now on lock-down...
Would this Router serfice?
http://www.tigerdirect.com/applica [...] &CatId=373
And if so, I can just plug this into the same phone line the other DSL router is running on, correct? I don't need to get a seperate phone line?
Thank for putting up with my networking ignorence :sarcastic:
Message edited by integraoligist on 03-25-2009 at 01:47:44 AM
Reply to integraoligist
Don't get a Draft N router. Stick with a G. No, make sure the new router has a different IP address than the old one. Run a network cable from a local port on the old router to the Internet port on the new one.
Grumpy
Reply to Grumpy9117
After looking at the G Routers I see that you don't need to connect it to the phone line at all, just directly to the original DSL router. I found this, even though the speed is 54mbps, this should be suffeciant for the customers in a 2000 sq. ft. 1 floor unit, correct?
http://www.tigerdirect.com/applica [...] etailspecs
Thanks again I appreciate it!
There are 1021 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
