Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > i have a heating issue with gpu and can't change fan speed
Forum Graphic & Displays : Graphics Cards - i have a heating issue with gpu and can't change fan speed
my 8600gt gets up to 89c.i can't change the fan speed because it goes back down to 30% when i start a game about 5 to 10 minutes in i think it causes low fps in my games. could it be my power supply that's causing this? is it not giving enough power to my system?
I'd like to turn the fan setting higher to cool it better, thanks
here's my specs:
Pentium 4 3.0ghz
1.5gb ram 2x 256 and 2x 512
8600gt 256mb
160gb 7200.rpm hard drive
DVD burner 24x
350w power supply
Sponsored Links
You have a perfect power supply for it. That shouldn't be the problem. Your card is definatly overheating, i will tell you that. Which software are you using for fan speed control??? If aren't already using this program, use RivaTuner, I use it and is a very good programming. Also ntune is a good program for fan control. make sure you have a well ventilated case and open it up if it helps.
Reply to blackhawk1928
There are 789 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
