im planing on doing a little upgrade i already dicided to buy these:
Intel q6600 - $189.99
Evga 9800gtx - $169.99
Kingston HyperX 4GB (4 x 1GB) 1066 - $81.99
but cant freaking decide on a motherboard i looked at the Asus P5Q - $129.99, but it just has one pci 2.0, i will like the option of sling my gtx some day if i need to, i saw the 780i line all crossing $230 wich dont fit on my budget, i though i could upgrade my pc with 600 guess i need more, but maybeu guys can give idea of a good board withing a good price....??
Sponsored Links
P5Q Pro
ATI 4850
Reply to Proximon
- 0 +
When trying to keep a low budget, Crossfire/SLI is rarely a good option, you would sacrifice performance now to be able to keep a system afloat maybe 1 more year (by then even that might be useless). I try to remind people that costed 600$+ less than 1.5 year ago are now being beaten by 250-300$ card; they might have well spend 300$ then and another 300$ to get similar or even better results.
I say put your money on a 4850 or 4870 and if you need more, just get a bargained 4870x2 or another mid-range GPU that will be equally good in a year.
------------------------------ The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. - Rebec of Ginaz
http://valid.canardpc.com/cache/banner/600609.png
Reply to Zenthar
- 0 +
i dont know about changing my idea about going with nvidia, but i do agree that 1 sigle good gpu is better option, i knew that b4 i came to the this forum, however I'am not rich and i cant change to a 300 dollar video card every 3 years thats why i prefere a good car like 9800gtx wich is slitly cheaper than the 4850 rite now, because u can play crysis in high settings with 4xaa, wich is perfect for me, if someday soemthing happen like crysis 2 comes out and i feel out dated i will just get another one that by then will be cheaper and sli, thats what its mean to look into the future and make ur ring last if i buy the best 500 dollar card, it will be of course like anything else outperformed by something new
Message edited by snakej on 09-09-2008 at 04:24:20 AM
Reply to snakej
- 0 +
ok guys i think ill go with the falowing:
HIS Radeon HD 4850 double cooling( http://www.newegg.com/Product/Prod [...] 6814161243 )
Kingston HyperX 4GB DDR2 1066( http://www.newegg.com/Product/Prod [...] 6820104058 )
ASUS P5Q Pro and Intel Core 2 Duo E8400 combo
everything for $560, pretty happy with setup if ya agree with it, ill buy!! lol
Message edited by snakej on 09-09-2008 at 04:43:25 AM
Reply to snakej
- 0 +
Yeah looks good, however this is the HD 4850 I bought... saving you $25-30 there.
SAPPHIRE 100245L Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6814102770
------------------------------ Anxiously awaiting the Hydra 100 and the Hydra Engine...
www.lucidlogix.com
Reply to emp
- 0 +
note:: some mobo's do not play well with 4x1 ram [timing problems i believe] better go 2x2,besides 4x1 will be harder to sell down the road..:)
Reply to dokk2
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > need help
There are 791 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
