I just built my i5 system tonight, I have the stock fan running at 100% all the time. My idle temps using RealTemp are 40-44 without ANY overclock... Under IntelBurnTest, it got up to 81 before I killed it (as it exceed the 78 max recommended by Intel)... under Orthos (Prime 95) it tops out around 70-72...
I have a CM Hyper 212 Plus on the way and don't plan on overclocking until then, but don't these temperatures seem high for a non-overclock on a stock fan running at 100% constantly...
This is bios defaults as well with C1E, C-STATES, etc.. enabled.
Motherboard is GA-P55-UD4P... Ambient room temperate, not sure... the room is around 23, but my CPU is inside an armoire (that remains opened but is solid wood on 2 sides, vented on back). It's probably at least 25-30 where the case is... Case side panel is off (always is).
Edit/Delete Message
Edit/Delete Message
