Hey guys, just hoping you could take a quick look and make sure I have everything I need. Sometimes I stare at something so long I miss the obvious. This is mainly a gaming machine but I decided to go with a quad core because I figured it would give it a longer lifespan.
Is that a decent monitor? I know Asus is good (never heard anything about their monitors though). It has the stats I'm looking for however, a 22" wide screen LCD with a 1680 x 1050 resolution and a 2ms response time.
I've never had a VisionTek video card but the reviews on newegg are positive (for whatever that is worth), but I could get the Sapphire 4870 for $10 more ($10 less if the mail in rebate goes through). But the $10 is of little consequence so I'd rather go with whichever is the more reputable brand.
Is the Q9950 worth it, or would it be better to save $55 and go with the Q9400? I plan on OCing which ever to at least 3.0 GHz down the road a bit, maybe a little higher if it doesn't hurt the lifespan of the CPU. Even with the Q9950 it's still within my budget of <= $1,500 total, just wondering if you had any opinions. How big of a difference would I see going from a 6MB cache to a 12MB?
Aside from that I'd just like to make sure I'm not missing anything. Should I throw a couple SATA cables in with it? How many of those three 120mm optional fans do you think I'll need to keep everything at a nice low temp? Can anyone recommend a decent fan? I've never purchased any.
Any other recommendations on different components, or maybe a different supplier for some of it where I can get a better deal?
If everything is good I suppose I'll order ASAP, hopefully some of those deals will still be in place. Sorry for the long read, I like to be thorough. Thanks guys (and gals... maybe? nahh, probably not)
I'd drop the Q9550 in favor of the Q9450, and switch to a X38 board for about $40 (better OC'er + you get full x16/x16 for future crossfire instead of x8/x8 lanes).
You're going to need one or two extra fans, the Three hundred already comes with some. visiontek is a good brand, only Ati partner that offers a lifetime warranty on their cards.
The screen looks good as far as I can tell, even though I know my way around LCDs, I'm not the most knowledgeable person on the matter so I'll let someone else take care of that.
Solid build, well thought out with room to expand in the future. There's only a $5 difference between the Q9450 and the Q9550, why would he go with the Q9450?
Other than those ideas/suggestions, I'd stick with what Emp has to say. The rest looks pretty good. You can tweak the DDR2 a bit, but I'd just stick with quality 800mHz stuff.
Message edited by lunyone on 09-09-2008 at 08:10:54 AM
You even threw in a 2ms monitor. Big Thumbs UP The only thing I'd change would be going with a retail burner. I mean really the cost difference is negligible and they put in nice things like extra screws and a SATA cable. I guess you could also find some value in the usual included copy of Nero or Roxio in case you don't have a copy already.
------------------------------Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
Be realy cafull when choosing monitor 2ms and 160 degres wieving range are typical for TN dispalays and they are cheap but colors are not that great.
178 degres +- some are for other 2 diplay types and they are much better at color reproduction but have higher refres times. I would not go with asus, but chose HP or samsung instead probably.
I like Visionteks warranty and their site. It's quick to access and has a consumer forum for information. In the past i've gone to big box retail stores and checked out different monitors side by side. It helps to see what you're thinking about buying. Good point by Mega about getting the retail burner for software and cable, your motherboard will come with a couple of SATA cables. Best place for cooler reviews is www.frostytech.com they have top 5 (10) ratings for coolest and quietest.
You might be able to save some money and get a AMD certified power supply:
ATI Radeon HD 4870 System Requirements
500 Watt or greater power supply with two 75W 6-pin PCI Express® power connectors recommended (600 Watt and four 6-pin connectors for ATI CrossFireX™ technology in dual mode)
Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products.
+1 @dirtmountain. In fact, I often spend a little more and get my monitors from brick and mortar stores. I will have seen them first, and don't need to worry about a "7 dead pixel" policy for returns. I want NO dead pixels on my monitor. That said, I bought my current Acer 22" from Newegg (would have become a secondary if any dead pixels), and was not disappointed.
Good choice on the RAM, although right now OCZ has a 4GB kit that also runs at 1.8v for $56 after MIR. The timings aren't as good, but you probably won't see a difference, and you can oc it yourself.
I think the build overall looks good. That it is a little more than you need is not a ding on that excellent PSU.
The only thing I'd change is the case. The CoolerMaster RC-690 is very similar to the Antec 300 with one nice difference: the bottom-mounted PSU does not have to be mounted upside-down, because it can pull its air up from the bottom of the case. In the Antec-300, there is no opening in the bottom of the case under the PSU. It will be pulling warm air down toward itself, which is counter intuitive.
------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
I second what xrodney said. This in a TN monitor. We had 4 of these Asuses (I don't know if exactly the same model). Colors are bad. One of them flickered too much. Not so great QC. We switched them to Samsung. I'd go with Samsung or Dell - best price/performance.
Message edited by tamirch1 on 09-09-2008 at 03:22:05 PM
