Motherboard help...
I have recently aquired an Intel Core 2 Duo 6400 SL9S9 MALAY CPU, 2 sticks of PNY DDR2 RAM (64AOTFTHE-HS), and an e-GeForce 8800 GTS video card (PCIe).
The only other peripheral I have that may be of concern is my SoundBlaster Audigy 2 ZS Platinmun. My case is an ATX mid-tower.
I need a motherboard and am not sure which way to go. I primarily use my PC for gaming... I don't have any preferance on brands, I just need help with compatability issues with hardware. I also have some concern as to price. Obviously, I don't want to spend more than I have to.
Can anyone help or steer me in the right direction?
Thank you for your time and efforts.
Mike
2 answers Last reply
More about motherboard help
  1. first question you want SLI, two what is your budget ?
    and 3 is that sound blaster a PCIe1x?
  2. On a budget consider this board to see if it has the features you need:
    Gigabyte GA-EP43-DS3L $80
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128347
    The part # you gave for memory does not match anything from PNY, so I can't verify compatibility.
Motherboards Product
