Good evening guys, was hoping someone with a good amount of overclocking experiance can give me some help!
I recently got myself a new PC, pre-built and overclocked, full specs can be found here (http://www.overclockers.co.uk/showproduct.php?prodid=FS-030-OE) i had the HD5770 graphics card option.
Now..im not one to mess with overclocking tbh, however that offer was quite nice as i was in need of a new pc.
I decided to run a prime95 test to check the heat etc, after 6 minutes my cores were running at between 80-84c.
Im idle at about 50c.
Is this an ok heat to be at? as im rather worried im going to damage something...
My system specs are exactly as descriped in the link, and below in case the link doesnt work..
Case Coolermaster elite 335
Graphics Card HD 5770
Hard Drive Performance 7200RPM Options
Memory Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel
Motherboard Gigabyte EX58-UD3R Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
Optical Drive LG GH22NS30 22x DVD±RW SATA Dual Layer ReWriter
Power Supply Corsair TX 650W ATX2.2 SLI Compliant PSU
Processor Intel Core i7 920 2.66Ghz D0 Overclocked to 3.40GHz!
Processor Cooler Akasa AK-967 Nero Direct Contact Heatpipe CPU Cooler
Sound Card 7.1 High Definition OnBoard Sound Card
Other Arctic Silver 5 heatsink compound professionally hand installed by our technicians
Thanks for any help or info you can provide
