Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > TV Tuner Cards > ATI 3870 HDMI audio problems no sound help!
Forum Graphics & Displays : TV Tuner Cards ATI 3870 HDMI audio problems no sound help!
Hi, Im looking to hook up my Pc to my TV via HDMI and since I have an HD 3870 in the pc id like to have the audio routed through it as well (which it is supposed to be able to do). I am using the integrated realtek audio and a Sapphire Hd 3870 to a 46 inch Sony bravia TV. I have used the provided DVI to HDMI adapter from ATI and all the connections are correct. There is no sound....
I have installed the realtek HDMI out drivers and under my sound control panel in vista I see Regular speakers, Digital output, and ATI HDMI output. However, I am unable to select the HDMI option as my default and it says it is not plugged in, it automatically sets Digital output as my default and shows that it is playing but again no sound comes out of the TV speakers (which are correctly configured). I am so absolutely lost, latest drivers are installed, someone tell me what im doing wrong.
The motherboard has integrated video and the bios has audio over HDMI option but I have disabled it because im quite certain it refers to the integrated audio (also disabled). Any help would be appreciated.
Reply to rapsux321
try going to control panel/sound/ audio see choices
------------------------------ 8088 @ 2 mhz
Reply to fleakiller
Use the ATI HDMI output as the default Windows sound device.
Reply to stridervm
Hi, under the control panel sound It says the realtek HDMi audio is unplugged, thus I cannot set it as default. Unless you are saying there is another way? It is not unplugged though, I have no idea why it says it is.
Reply to rapsux321
- 0 +
DVI only does video no sound. So if you use a dvi to hdmi you will only get video at one source. You need hdmi to hdmi for both video and sound.
Reply to macblob
Why are you trying to set the realtec HDMI as default if you want the Audio to come from the ATI source ?
Im not sure but i think you still need the onboard Audio enabled, I dont think the ATI card has the ability to generate its own audio but rather route's the onboard but i may well be 100% wrong on that.
As far as being unpluged goes, when i built my system a few months back i had a choice of which audio i plugged in to the header, HDMI or the AC 97 so it could be that simple.
I am 100% sure that the ATI DVI is differant to a standard one though and what macblob says is correct with standard set ups but as i said the ATI DVI isnt standard.
Mactronix
Reply to mactronix
- 0 +
1. make sure you use the correct DVI to HDMI adapter that came with your box. E.g the one that comes with 4870 will not work with 2400 or 2600.
2. I have ATI 4870 and had HDMI audio drop problem previously. I was able to resolve the problem by disabling the ATI external event utility service in services.msc, read below for details. It really works:
http://www.avsforum.com/avs-vb/sho [...] stcount=27
Reply to midiman
Uh, the DVI on the 3870 DOES output sound. I ran HDMI cable from the DVI output (with the adaptor) to my HDTV, and then an optical cable from the TV to my tuner. The sound signal came from somewhere. ;) You should also be able to get sound from the TV speakers, though.
Make sure you are using the Rear HD Audio hardware as your default audio device, and that you have the drivers installed.
If you want to use surround sound, you'll also need to go to the Audio tab and click Advanced and set the speakers to 5.1 or 7.1, whichever apply.
Reply to Cannukko
i also have this problem the only difference being that my version of the HD 3870 has a HDMI out built in
Reply to smegskull
For vista at least, this should solve many issues:
control panel: sound
playback tab, you should have an HDMI sound option, set that as default.
Reply to Anonymous
I had the same problem
Make sure you have hdmi to hdmi and the adapter(dvi to dvi or dvi to hdmi does not carry sound)
I found that if in device manager you enable show hidden hardware, the ATI device shows and you update the drivers from the windows website it will work. Not sure how this worked but i promise you it did !!
Installing realtek drivers does work if you have a realtek onboard.
Reply to dhitchen
The "ATI HDMI Output" option on the SOUND section of the control panel should be set as default to work.
I have made it to work on 3870 , 4870, and 4890 on Vista-64 Ultimate.
Limited Experiment on 4890:
Important thing to note is dansobolanu's input of using the DVI-HDMI converter from ATI. Other 3rd Party DVI/HDMI converter don't work. I went to frys & tried different brands and got no audio.
The option is "ATI HDMI Output".... Without the correct DVI-HDMI converter (The one from ATI) this option don't show up on the SOUND section of the control panel.
I tried different 3rd party DVI/HDMI connector and it just doesn't work. The option " ATI HDMI Output" don't appear on the SOUND section of the control Panel. Ati software may be detecting some sort of ID on the connector.... I'm not sure & i may be wrong.
I'll be calling Diamond Multimedia tomorrow regarding this, and I need another DV-HDMI converter (From ATI).
The 3rd party brands of DVI/HDMI converte that i tried this weekend are PTC, Link-Depot, Belkin, and another less popular brand. Got no audio on these converters.
On the 4890 i can get audio on both DVI outputs using the ATI DVI-HDMI converter.
------------------------------ Q6600: Maximus Formula: CorsairH50:8GByte: Crucial Ballistics 4-4-4-12: PC6400; Vista Ultimate-64BFG XOC 4890; Disp: 70 Inch HDTV: Hauppage 2250 HDTV Tuner1.4TByte: 2x750Gbyte; RAID0; Case: Antec 900: PS:Antec Quatro 850
Reply to leon2006
I talked to Diamond Multimedia tech support this morning got the following response when i asked why 3rd party converter dont pass the audio.
"There is a chip inside the (From ATi)DVI-HDMI converter to PASS both video and Audio".
I requested an extra converter and Diamond is to ship me another connector.
I also tried to use the DVI-HDMI converter from BFG. When using GTX-280 i can get Video and Audio through HDMI. But when i use the BFG connector(DVI to HDMI) on 4890 only the video gets through.
So to date in my case to get audio/video on HDMI is to use ATI supplied DVI-HDMI converter/connector. Using other connector only video is pass through the HDTV.
Reply to leon2006
If this is any help. I have a 4850 card and used the packaged dvi to hdmi adaptor. with all the installed drivers cat ver 9.9 I would get ati hdmi cable not connected. I found my problem was as stupid as having two dvi outs that were color coded. A white dvi out and a yellow dvi out that just so happend to match the yellow dvi to hdmi adaptor. Once i plugged into the yellow the audio magically worked.
Reply to Anonymous
I have not done this, but my reading says ATI cards are different from others in that they DO make audio signals available at the DVI connector so that using their adapter to create the HDMI connection does provide audio on the HDMI lines. However, there's also the question of where that audio signal comes from. I understand that some ATI video cards with this feature do NOT create any audio. Instead there is an included separate cable that merely connects the signal from the mobo's audio pinout connector to the ATI video card so it can be passed through to the DVI / HDMI output. Don't know about your card, but check if you need to use such a cable.
Reply to Paperdoc
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1638 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 6 hours ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
