hi so this will be my first build and im not completely sure of everything that i need compatible. i was wondering if you guys could help me check compatibility of my build and my build item picks.
-Two 4870x2 or one 4870x2? ......either way might consider bigger monitor since the 22" would limit the capability of the GPU.
-I have been told VelociRaptors a litter overkill.
Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
or
Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive
-Memory: I like Corsair. Their site has a nice memory config program.
DDR2 800. I have the same MOBO and got Twin2x4096-6400C4DHX (4-4-4-12) (Corsair)....works great.
Really nothing else I can think of to the nice build
I went with just one ATI HD4870 gpu and two 500gb Seagate Barracuda's. I also have 2X4gb Mushkin PC2-8500 ram. I have heard good things about them.
I chose not to get a sound card because the Gigabyte EP-45-Extreme mobo has the HD audio built in. I think if you wanted to really build an extreme gaming machine then maybe but for the most part I don't think you'll need it.
Thanks guys im glad i can piece together a system that makes me very happy.
The GPU: ASUS EAH4870X2/HTDI/2G Radeon HD 4870 X2 2GB is not 2 memory cards it is a new card just recently released that has 2gb of memory in the single card. im not sure if i should go with 2 of these to run on the new t260 samsung 26" monitor.
as for sound card i think it should be good for now and even if i want to get one i can always wait and upgrade later.
also atm im leaning towards the mushkin ram with the heat spreaders but first im going to get my mobo to check out the spacing and see if 4 of them with heat spreaders would fit.
thank you a ton for your input and ridiculously fast response. i have been trying to get help with this for nearly 2 weeks and then i found this forum.
any further input is always appreciated.
as it turns out these both work with rampage and the heat spreaders on the second link do fit asus boards. just curious as to what your recommendations are for running 8gb ram (from one of these choices).
since their specs are a pretty close call im curious about reliability, ocing, experiences you have had with them, etc.
any input is appreciated
