Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > HELP! New Video card killed my sound!
Forum Homebuilt Systems : General Homebuilt - HELP! New Video card killed my sound!
So I recently upgraded my video card from an 'ASUS 9600GSO TOP' to an 'ASUS EAH4850'. The video card is the ONLY thing that's changed in the computer, and now I only get audio from my left speaker! I've never had any issues with this PC before, and everything was working great before I made the switch. As a note, I'm running Altec Lansing 2-ways + self powered sub. The sound is output to the sub, then rerouted to the speakers themselves. The left one is the only one that works, but the volume, bass and treble control are mounted on the right speaker, and they work fine. Because of this, I can only assume that it's not a hardware issue with the speakers.
So my forst step, naturally, was to make sure everything was seated correctly as far as speaker cables and such. Then I asked around a bit and found out that the ATI cards install an audio driver for the HDMI output, so I went through that sound options to make sure that the on-board sound card was still the default device; it is. Next I went in to the device manager and disabled the ATI audio driver, still no help. The only option I saw left was to reinstall the sound drivers, but when I went to uninstall the Realtek drivers, I got a generic '-500 runtime' error. So I booted into the BIOS, disabled the sound card, booted into safe mode, uninstalled the driver, rebooted into BIOS, activated the card, then went through the normal channels to reinstall the Realtek drivers. Now I'm back to square one with only sound out of the left channel. So... failing all this, I decide to go for the whole shebang. I rebooted to safe mode and uninstalled EVERYTHING. I stripped the drivers for the board, chipset, soundcard and video card. I then checked for any ghost or hidden drivers through device manager, and rebooted to Windows; installing all the drivers from scratch. And as you can guess... still no help!
Can anyone tell me what is going on here!? I've plugged the speakers in to my iPod and they work just fine. The on-board sound was running perfectly before I swapped out the video cards, so I can't see it being that. I have no other cards plugged in to expansion ports, so it's not a conflict with another device. It HAS to be a driver issue of some kind but I can't figure it out!
Motherboard: GA-M57SLI-S4 (onboard sound)
Video: ASUS EAH4850
*Note* I'm using the drivers that came with the disk for the video card.(8.500.0.0) I've tried with the latest drivers, and with and without the software suite that's included. The HDMI drivers seem to install no matter what.
Sponsored Links
OK, so I went into the device manager again and uninstalled the "ATI Function Driver For High Definition Audio". That led to no sound at all, even though I had the realtek drivers installed! So for some reason, the realtek drivers aren't getting used for the sound. When I rebooted the PC, Windows popped up a found new hardware message and reinstalled the ATI drivers right away. Now I'm back to single speaker sound.
So now I'm SURE that the ATI drivers are overwriting and/or dissabling the Realtek drivers somehow... now how do I fix it?
Reply to caldezar
Hi,
my friend's onboard sound was half dead like yours (left channel ok only) in a power outage.
So you may have killed yours with static while installing your new videocard.
You can buy a new soundcard or ask an RMA with gigabyte.
Try to install the old videocard too.
Brad
Reply to djbrad007
Heading out to buy an Audigy SE since they're only about $25. We'll see if that helps...
Reply to caldezar
There are 1072 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
