I have a modular psu but its still messy with all the wiring. is it safe to hide it under the mobo or will it short it?
The Maximus II Formula puts its 8-pin and 24-pin power connectors along the top and front edges, which make for easy cable routing to a top-mounted power supply. Builders stuck with a bottom-mounted power supply will appreciate that the 8-pin connector is close enough to the top edge to pull a cable up from behind the motherboard tray, but any cable folded over the top would cover the latch.
