HP Intel Core 2 Quad 2.4
Model: M8517C-B
# Processor and Memory: Intel® Core 2 Quad Processor Q6600
# 5120MB PC2-6400 DDR2 SDRAM memory (1x2048MB 3x1024MB) (expandable to 8GB)
Hard Drive and Multimedia Drives:
# 750GB 7200RPM SATA hard drive
# SuperMulti DVD Burner with LightScribe Technology: 16x DVDR, 8x DVD+RW, 6x DVD-RW, 8x DVD+R DL, 4x DVD-R DL, 5x DVD-RAM, 16x DVD-ROM, 40x CDR, 32x CDRW, 40x CD-ROM
Audio, Video and Graphics:
# High Definition Audio, 8 speaker configurable
# Intel® Graphics Media Accelerator 3100 with 128MB dedicated graphics memory; up to 287MB total available graphics memory as allocated by Windows Vista
Ports/Slots:
# 2 external 5.25" (one available)
# 1 external 3.5" (one available)
# 2 internal 3.5" (one available)
# 1 PCI (occupied)
# 2 PCI Express x1 (available)
# 1 PCI Express x16 (available)
# Front panel 15-in-1 memory card reader supports Smart Media, xD, MultiMedia Card, Secure Digital (SD), Compact Flash I, Compact Flash II, Memory Stick, Memory Stick Pro, Memory Stick Duo, Memory Stick Pro Duo, RSMMC, MMC Mobile, MMC+, Mini Secure Digital, IBM Microdrive
# 6 USB 2.0 port(s) (2 front, 4 back)
# 2 FireWire (IEEE 1394) port(s) (1 front, 1 back)
# Headphone; Microphone (front)
# 2 PS/2; Digital Audio Out; LAN; Microphone/Line-in/Line-out; Rear speaker-out; Side speaker-out; Center (subwoofer); VGA-out (back)
Operating System:
# Genuine Windows Vista® Home Premium 64-bit edition with Service Pack 1
This is the Graphic Card I intend to buy...
Graphics Card:
BFG GeForce 9800GTX 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retai
l
[System Requirements 475W PCI Express-compliant system power supply with a combined 12V current rating of 26A or more***
Two 6-pin PCI Express supplementary power connectors -or- One 6-pin PCI Express and two 4-pin Molex supplementary power connectors
Minimum system power requirement based on a PC configured with an Intel Core2 Duo E4500 processor.
Power Connector 2 x 6 Pin]
Now when im looking for the power supply is there anything specific I am looking for other than that I need at least 750W to run my computer w graphic card?
Do all power supplies come with the same kind and number of "pins"?
Any suggestions on type of power supply I should get?
Sponsored Links
My $.02
http://www.newegg.com/Product/Prod [...] 6817379006
$185 Zalman 750W (LED's are bright tho)
or:
http://www.newegg.com/Product/Prod [...] 6817379007
$215 Zalman 850W (peak 1050) Quad SLI certified (no LED's)
Reply to IH8U
you dont need 750w to run a q6600 and a 9800gtx. a good quality 400 or 500w is plenty. here are some psu that will run your system fine. no need to waste soo much money.
http://www.newegg.com/Product/Prod [...] 6817159074
http://www.newegg.com/Product/Prod [...] 6817341012
http://www.newegg.com/Product/Prod [...] 6817371019
------------------------------ intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI Extreme sound) 6gig of OCZ+CoRSAIR oc 900mhz Nvidia gtx 260 sli @ 730/1465/1250
Lite-On Blue-ray Western Digital 7200rpm 500gb Antec 500 Earthwatt Window vista 64-bit
Reply to invisik
Corsair TX 650/750
Corsair VX450
Any Seasonic
Id personally dodge Coolmax and the Antec Basiqs (other antecs are fine though)
Main thing with PSU is quality. Thats the regulation (close to 3.3,5, and 12 v) Efficiency, ripple and the build quality based on the OEM. Corsair is constantly good working with Seasonic and CWT OEM psus which are great.
If u have any questions just ask. For reviews check out Jonnyguru.com or Hard OCP. They test PSUs very well
------------------------------ Antec 1200|Antec Signature 850w|Asus Maximus II Formula|Q9650|4GB Dominator 1066|EVGA 9800GX2
Reply to Silverion77
IMO the best deal today is:
CORSAIR CMPSU-650TX $59.99 after rebate
http://www.newegg.com/Product/Prod [...] -_-Product
Corsair is good for their rebates, unlike some others.
Reply to knotknut
Silverion77 wrote :
Corsair TX 650/750
Corsair VX450
Any Seasonic
Hold up there a minute doesn't a 9800 GTX require dual 6-pin power connectors. I think you would need at least a Corsair VX550 - the VX450 only has 1 - to support 2 PCIe power connectors (OK sure you could do evil things with molex to PCIe power convertors):
450 VX spec: http://www.newegg.com/Product/Prod [...] 20450%20VX
9800 GTX spec: http://www.newegg.com/Product/Prod [...] 6814133246
Bob
Reply to bobwya
Agree with most of the suggestions here (except the ludicrous 700w-900w suggestions)
Any "Decent branded" PSU in the area of 500-600 will be plenty for the system.
Corsair, Antec, PCP&C, Seasonic
------------------------------ "This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
Check newegg. They have the Earthwatts 500W for $49.99 again. 34A on the 12V rails, and two 6pin PCIe plugs. This PSU is normally $90, so this is a great deal.
Whats with the odd RAM configuration? Also, what OEM is this? You might be better off just building one from scratch.
------------------------------ The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power Supply Help! PleasE!
There are 721 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
