Sign-in / Sign-up
Amount of fluid for charging the heat pipe
  • Heatsinks
  • Heat
  • Overclocking
December 7, 2009 8:22:20 AM
Please tell me someone who know the amount of fluid for charge of heat pipe :bounce:
More about : amount fluid charging heat pipe
a c 86 K Overclocking
December 7, 2009 8:35:51 AM
It's done under vaccum. And usually special liquid. Thats from what I have read.
m
l
a b K Overclocking
December 7, 2009 11:04:19 AM
Welcome to the forums!
A heat pipe is filled, under a vacuum, with a 'fraction of a percent by volume' (well under 1% of the volume) by water, ethanol, acetone, sodium, mercury or some other coolant.
Source: Wiki Heat Pipe Page
m
l
a b K Overclocking
December 7, 2009 6:10:23 PM
The pressure depends on the liquid used.
E.X. If its wat er then you will need to drop the pressure a lot.
If its propane on the other hand, you will need to reaise the pressure til the boiling point is in the positive #'s.
m
l
January 12, 2010 9:51:22 PM
HVYMTL
Just a thought , propane may not be a good choice. R-11 although no longer in use today due to its contributing factors in ozone depletion would have made a good choice when used as a refrigerant in a Heat Pipe.
I have provided a link that can let the viewer make their own choice. l
m
l
January 13, 2010 1:52:57 AM
It's charged in a vacuum room, and each manufacturer uses it's own liquid. Unless you have a setup for doing this it's not worth your time.
m
l
