I recently bought parts to build a system and unfortunately it wasn't long till I encountered a problem. I put my PSU an intel quad core http://www.newegg.com/Product/Product.aspx?Item=N82E16819115018 into my motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299 (correctly so far as I can tell, aligning the gold triangle to the bottom left of the socket) but when I try to close the metal load plate, it seems to be putting a good deal of pressure on the PSU chip. I examined the plate and it looked like it was slightly bent, so I used some pliers and tried to straighten it as best I could. This seemed to help but I can still only close the load plate about 2/3 of the way before I would need to put a seemingly undue amount of pressure on it to get it closed. I should point out that this is the first time I am trying to build a computer so I wanted to ask someone experienced for guidance as to how to proceed. Any help would be greatly appreciated, thank you!
