I'm trying to connect to my home pc (running windows 7) from work. I have an AT&T (dsl) 2wire router. I set up a DMZ for my home computer. When I try to access the computer locally, it works fine. When I try to access it via IP it does not connect though. The only firewall is the windows default firewall, which is set to let RDC through. After trying to initialize the connection for a couple seconds it gives me an error box with 3 possible reasons why it didn't work.
Can anyone help?
