Usb has exceeded power limits
  • Hard Drives
  • Connection
  • USB
  • Power
  • Storage
Last response: in Storage
Anonymous
a b G Storage
February 13, 2010 3:28:40 AM
when i connect my 250 external it shows a usb has execeed power limits
More about : usb exceeded power limits
February 13, 2010 5:09:42 AM
250 what? What you using? external hdd?
I had a similar problem for a bit few months ago when i made my own usb case fun mod thing... it disappeared quickly enough
a c 415 G Storage
February 13, 2010 7:03:38 AM
If it's a full-sized external drive, that's normal. It's generally only the 2.5" external drives that have low enough power needs that they can be powered by a USB port.
USB 3.0 may change this since it permits attached devices to draw somewhat more power than USB 2.0.
a b G Storage
February 13, 2010 2:45:28 PM
try a powered usb hub, they are a few bucks at any local shop
a c 353 G Storage
February 15, 2010 2:47:40 AM
Sminlal is correct, and 505090 provided the corrective action for a 2 1/2 in HDD. For a 3 1/2 in drive a 12 Volt brick is required Vs the 5 Volt usb hub brick.
3 1/2 in regular HDDs require +12 V, not provided by a usb port. Usb Ports are low current (power) and even some of the 2 1/2 in HDDs exceed the power limitations for a usb port and require a "Brick"
