System starts. Goes through post with no errors and then goes to black screen with no activity. If I try going into bios I get the same thing. Not really sure where to go from here. Any advice would be greatly appreciated.
Could be a couple of things. The first as that your power supply is too week. Try taking out your Radeon and using the onboard video since thats a G31 board. If you can get into your BIOS after that then get a bigger power supply. If not disconnect all your devices and try booting it with one RAM stick and then the other. You could have bad RAM or another device that isn't playing nice with your systems BIOS. If you still can't get into the BIOS screen, then you mighnt have a bad board or corrupted BIOS, which means you RMA that board.
Message edited by megamanx00 on 09-11-2008 at 08:08:58 PM
------------------------------Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
+1 @Evongugg. Use the integrated video. Change the BIOS settings to init the PEG graphics card first. Then reconnect to the Radeon and reboot.
------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
Thanks for the replies. I removed the radeon card and hooked up to internal graphics. Was able to get into bios just fine. Peg is set to iniate first by default. I suspect its a psu issue. For the sake of saving a couple bucks I spent $20 on a 585w psu. The thing weighs less than my cell phone so I should have been more suspicious to begin with. It also has no dedicated pci-e connector. Instead using a molex to pcie adapter. Could that be an issue? Seems that 585w should be more than enough power for what I've got.
