R.G.B.: Auto
CPU Clock Ratio: 9X
CPU Host Clock Control: Enabled
CPU Host Frequency (Mhz): 333
PCI Express Frequency (Mhz): 100
C.I.A.2: Disabled
Performance Enhance: Standard
System Memory Multiplier (SPD): 2.0
Memory Frequency (Mhz): 667
CAS Latency Time: 5
Dram RAS# to CAS# Delay: 5
Dram RAS# Precharge Delay: 5
Precharge Delay (tRAS): 12
ACT to ACT Delay (tRRD): Auto(4)
Rank Write to READ Delay: Auto(4)
Write to Precharge Delay: Auto(8)
Refresh to ACT Delay: Auto(68)
Read to Precharge Delay: Auto(4)
Static tRead Value: Auto(4)
Static tRead Phase Adjust: Auto(0)
System Voltage Control: Manual
DDR2 OverVoltage Control: +0.2v
FSB OverVoltage Control: +0.1v
(G)MCH OverVoltage Control: +0.1v
CPU Voltage Control: 1.381
Normal CPU Vcore:1.325
Then, I hit F10 and restarted. It still shows 2.40GHz(267x9), DDR2 is at 534Mhz instead of 667 (which means CPU Host Frequency didn't change at all). So, I tried different combinations between voltage, it didn't work. I also tried to OC to 2.8GHz only, it didn't work either. CPU Host Frequency resets to 267 everytime I restat. Need help asap, Thank you.
I have a similar setup, i also OC my board to 3.0ghz. My board resets it randomly all the time. Sometimes it takes months, othertimes days. I have yet to find a solution. I have also tried the 2 suggestions posted. They have not worked for me. I have also had many more problems with this particular board, and i recommend to stay away from it. Once that tax return comes, i will have a new board.
