ati3duag.dll problem
Everytime I try to play a game NBA LIVE 08, NEED FOR SPEED CARBON on my pc, this blue screen pops up: but other games like starcraft works.
| A problem has been detected and windows has shut down to prevent damage to
| your computer.
| If this is the first time you've seen this Stop error screen restart your
| computer. If this screen appears again follow these steps:
| Check to make sure you have adequate disk space. If a driver is identified
| in the Stop message, disable the driver or check with the manufacturer for
| updates. Try changing video adapters.
| Check with your hardware vendor for any BIOS updates. Disable BIOS memory
| options such as caching or shadowing. If you need to use safe mode to remove
| or disable components, restart your computer, Press F8 to select advanced
| startup options and then select safe mode.
| Technical Information:
| ***STOP:0x0000008E(0x0000005, 0xBFA88ACD 0xAFE382EB, 0x00000000)
| ***ati3duag.dll-address BFA88ACD base at BFA33000, Datestamp3F627fb6
| Beginning dump of physical memory.
| Physical memory dump complete.
| Contact your system administrator or technical support group for further
| assistance
| Can anyone help me?
These are my SYSTEM SPECS:
INTEL CORE 2 DUO 2.53 Ghz
Kingston ddr2 667 1gb
ATI Radeon X1650 Pro PCI Express 512mb
Samsung SATA 160gb
PLEASE HELP ME...
2 answers Last reply
More about ati3duag problem
  1. Thanks for the help MegaGamer3... But my Video card is PCI Express, I think it wouldn't help..
    I forgot to write down my Operating System on the list and Motherboard.
    CPU: INTEL CORE 2 DUO 2.53 Ghz
    Memory: Kingston ddr2 667 1gb
    Video Card: ATI Radeon X1650 Pro PCI Express 512mb
    H.D.: Samsung SATA 160gb
    O.S.: Microsoft Windows XP Professional Version 2002 Service Pack 2
    Motherboard: ECS 671T-M3
    HELP PLeAsE.
Radeon Graphics
