Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > help picking a graphics card
Forum Graphic & Displays : Graphics Cards - help picking a graphics card
i use a 20" 1680x1050 res monitor. i want to be able to run MOST games at least at medium settings at this resolution with 60+ fps. all i'm gonna play are shooters and a little spore. so would an 8800gt do well with most games at medium+ settings at this res, or would i need a better card?
if i need a better card, is the performance difference between an 8800gt and a 9800gtx worth it? and is there a significant performance difference between the 9800gtx and the hd 4850?
Sponsored Links
You'll be able to play most games on medium settings at 1680x1050 with an 8800GT (9800GT) and get @60 fps. There's a small step between the performance of the 9800GT and the 9800GTX, small step to the 9800GTX+ and then a small step up to a HD4850. It's really a matter of budget, if you only spend $100-$110 then the 9800GT is a good choice, if you can spend $140-$150 then the HD4850 is a good choice.
http://www.newegg.com/Product/Prod [...] 6814127379
http://www.newegg.com/Product/Prod [...] 6814102770
Reply to dirtmountain
- 0 +
With the 4850 presently around the $150 mark, I would consider it the front runner for best bang for your buck.
Reply to grieve
^+1 for above posters.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to shadow703793
I agree except...the 9800GTX+ is faster than the HD4850.
Reply to metalweenis
The difference between 8800GT and 9800GT is 3 way SLI. If your not going to be running 3 cards in SLI. Go for the 8800GT. I'm running 2x8800GTs and i'm very impressed with the performance.
AJ
Reply to ajcroteau
There are 671 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
  • 01:00 dpnaugle won the Freshman badge
