I've recently started to look into overclocking my cpu (core 2 duo e8500) and before I did anything like that I wanted to see what temps my CPU is already running at. So I downloaded Core Temp and both cores at idle were running at about 51 C. I searched around a bit and found some sites saying that is way too high for an idle temp and some saying that it is okay. So can anyone clarify this for me?
Also, I downloaded prime95 to run the torture test to see my temps under a full load and both cores got up to around 64 C, with one core usually being 2 or 3 degrees higher than the other. I'm pretty sure this is too high, so I would like to know how I can fix this. Is there any way for me to increase my fan speeds? I downloaded and ran SpeedFan and it shows this:
Why does it say that only one of my fans is running? Why are the rest of them at 0 RPM?
