Solved
Q6600 overclocking help
December 13, 2009 2:20:42 PM
am asking if i could over clock my CPU to any MHZ better than 2.4 , just the only problem am using the stock fan my temp is 36 38 32 31 overall 27 in non load i dunno if i can over clock or not and if i could how could i over clock and how much ?
am using
Mother board Gigabyte P31
3 giga ram
Ati 4850 1 giga
PSW hec 500 wtt
please help me ,sorry for my bad English!!!!
thanks in advance
More about : q6600 overclocking
Anonymous
a b à CPUs
a b K Overclocking
December 13, 2009 11:01:08 PM
you could probably get that atleast up to 2.6 GHz with what you have. It would help a lot if you got a better cooler or mobo, but your system should be able to handle it.
m
l
Anonymous
a b à CPUs
a b K Overclocking
December 14, 2009 7:48:19 AM
Hi,
Try this Q6600 @ 3.1 rock stable
raise CPU voltage to 1.3125v
set fsb to 345 * 9 = 3108
memory @690
add +0.15 to your mem voltage / mine is 1.95v (1.8+0.15)
disable hyperpath3
keep other on auto
OC ratio 1:1
check the temperatures,
stock cooler should be good enough...
Let me know how it goes<
m
l
December 14, 2009 9:17:14 AM
thanks guys i will try your way satenciatko but
i over clocked my CPU now to 3.0
and when i open CPU-Z i find the multiplier not stable sometimes it be 6 and sometimes its 9
so the core speed some times is 333*6 = 2 Ghz and some times 333*9= 3 Ghz i dunno what is that, should it be like this and when there's stress it become 9 !!!!!!! thanks in advance
m
l
Anonymous
a b à CPUs
a b K Overclocking
December 14, 2009 9:34:12 AM
disable * Intel Speed Step in BIOS - it is changing multiplier ...
disable * Enhanced C1 Control in BIOS
m
l
December 14, 2009 10:37:16 AM
i couldn't find any of them found something call CPU enhanced halt(CLE) i disable it and still the problem occur
m
l
December 14, 2009 11:40:32 AM
i set every thing to default and the weird thing that i find the multiplier still changing !!!!!!! is it the normal thing or there's a problem in my CPU please help mee !!!!
m
l
Best solution
Anonymous
a b à CPUs
a b K Overclocking
December 14, 2009 11:51:01 AM
In your bios it is called: CPU EIST function
Enhanced Intel SpeedStep® Technology
http://www.xbitlabs.com/images/mainboards/ga-ep35-ds4/b...
Let me know how it goes...
December 14, 2009 12:00:13 PM
thanks for your help but i disabled it and still have the same issue !!!!! am very worried now :(  !
m
l
December 14, 2009 12:16:56 PM
finally it worked i disabled EIST and the C1E thing and its 9 x now all the time thanks very very much satenciatko for your help
m
l
Anonymous
a b à CPUs
a b K Overclocking
December 14, 2009 12:26:20 PM
you are welcome....enjoy your 30%+ overclock.
you can go higher, but in that case I would recommend new cooler...
I found 3.1 as pretty good overclock ...
going up means higher watt consumption, more heat...
TAKE CARE
m
l
