Tom's Hardware > Forum > Motherboards & Memory > Memory > Memory or mobo problem
I have the Asus p5k vm motherboard. I have installed 4 gb (2X2gb) ddr2 800mhz corsair. The problem is that at the post message it only shows 3.3gb.
Sponsored Links
Not this again.
Sigh.
Let me guess, you are running a 32 bit Windows operating system.
For a 32 bit operating system (XP or Vista), that is normal. Max address space for a 32 bit address is 4 GB. Windows does a lot of behind the scenes memory mapping. That's where your missing memory went.
Check your BIOS. It should indicate the full 4 GB's.
Reply to jsc
I have vista 64. The problem is that the Bios recognizes only 3.3 gb
and when i installed extra 2 1gb sticks and bios indicated 5 gb.
Reply to unknown386
O.o - Look everyone, it's not the same frapping XP32 memory question!
Well, that changes a few things. First, it takes you out of the land of the noobs, congrats!
I'd say it's gotta be a bios setting somewhere, what else could it be? Shared memory with video? Something to do with the "Integrated IntelĀ® Graphics Media Accelerator 3100 High-definition video processing with a maximum resolution of 2048 x 1536 bpp @75 Hz Maximum shared memory of 256 MB"?
Reply to mford66215
Since you havent listed your specs, how could we know what the problem is?
If you have integrated video on your motherboard, it shares your system memory. Of course if you had bothered to read your mobo manual you would already know that.
That puts you back in the land of the noobs.
Reply to zipzoomflyhigh
There are 561 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
