does anyone know if there is a way to control the system fan speeds on this mobo?
most of the forum threads i have read only mention issues with the CPU fan control, but this works fine for me. my chasis fans are screeching at 2000rpm!
i've tried speedfan, but it doesn't work. unless i'm doing at wrong.
Where are your case fans plugged in? 'SYS_FAN2' is 'slaved' to the MCH temp (and is, on some MOBOs, buggy), not the MOBO temp; 'SYS_FAN1 and PWR_FAN have no speed control h'ware, and are best used just for sensing fan speeds 'split-off' the other two...
"What would happen if you stuck a non-PWM Sys Fan parallel to the CPU PWM header with a PWN CPU cooler attached? "
The parallel SysFan would run at 100% - the 12V pin on a PWM setup is ALWAYS at 12V - the speed control is accomplished by modulating the pin four 5V signal, which operates 12V switches on the fan itself...
I managed to split up the fan connectors and they work! You can see their fan speed and everything.
BUT! This motherboard still does not give you the option to control the sys_fan speed.
There is definitely a silver lining though, because the fans are running in parallel, so they run slow. Now they are nice and quiet at ~800rpm instead of 2000!
