Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > HELP installing a Graphics card OVER integrated GFX
Forum Graphic & Displays : Graphics Cards - HELP installing a Graphics card OVER integrated GFX
hello, i need help.
im going to buy a 4670 for my computer but i have integrated graphics.
im using a PC not a laptop.
i googled it and some people said that i had to disable my integrated GFX in the device manager, others said i had to go to my BIOS and disable it there.
can SOMEBODY give me a STEP-by-STEP walk through on how to do this.
this would be GREATLY appreciated! :bounce:
Sponsored Links
if you need my stats just ask
Reply to aj95
it is easy,
1- just install your new gpu (put it in the slot).
2-go to bios and disable the integrated gpu.
if that didnt work, then
1-go to bios and disable the integrated gpu.
2- just install your new gpu (put it in the slot).
how to disable in the bios. refer to your mobo's manual. it should be there. :)
------------------------------ Q6600 @ 3Ghz | zalman 9700NT cooler | gigabyte P35-DS3L | Kingstone DDR2 667 2GB x 2 | HIS 4850HD with Accelero S1 Rev.2 | enermax Liberty 500w | Coolermaster C5 case |
Reply to night_wolf_in
- 0 +
Make sure your BIOS defaults to looking for video cards in PCI-E or PCI.
Open up device manage
Uninstall the integrated drivers
Turn off computer
Put in video card
Start computer
Go in bios
Disable onboard video card
Save changes and start up windows
Install drivers from ATi's website
have fun -_-
Reply to Ares_
- 0 +
ok thanks guys
Reply to aj95
- 0 +
ok, i took a look at my BIOS settings and its on "<AUTO>"
for the video settings. i hit enter and it said <AUTO>
PCI-E (PEG)
PCI
( and 1 more thing i forgot)
when its on auto does it mean its waiting for a GFX card? or do i have to change it to PCI-E after i install GFX card??
Reply to aj95
- 0 +
^ Change the setting to PCI-E to be safe, although on AUTO the MB should automatically detect and use the new card of it`s own accord, it
wo n`t hurt to be polite and tell it.
Which is what ARES_ ment in the top line of his post, then boot up and follow his instructions from line two; Open up Device Manager.
Reply to coozie7
The auto selection usually works, but sometimes it quirky, so its best to "force" it and use the PCIE option
------------------------------ I went drifting, thru the capitols of tin, where men cant walk and cant freely talk, and sons turn their fathers in
Reply to jaydeejohn
- 0 +
OK, do i HAVE to uninstall the integrated GFX drivers? i mean i really don't know witch one is my drivers and i dont wanna uninstall something important..
Reply to aj95
- 0 +
cant i just skip a part of it and start from line 4? wich is turn off computer
Reply to aj95
Just install your current drivers, and see how it goes, and I mean current for your gfx card. If you uninstall the IGP drivers youll still have Windows drivers, which are slow, and will give you a resolution of 800x600, so dont be alarmed
Reply to jaydeejohn
There are 1168 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
