im having a problem with my wireless internet.
all the other laptops in the house work with the wireless connection but when i try connecting my vista laptop
the status of the connection says IPv6 limited i tried disabling it like most people do but the problem is with all the connections i try to connect to. when i connect the laptop directly to the router it sometimes works and sometimes doesnt . i need help
the IPv4 status is always local and internet
but the IPv6 is always limited
i trying manually configuring IP addresses but no usee.
Are you only concerned because it says limited on IPv6? Unless your network needs IPv6, it shouldn't be a problem to disable it and ignore the warnings. I mean, if you have internet connectivity, where is the problem?
