Tom's Hardware > Forum > Homebuilt Systems > New System Build > New build for 1500 help
Forum Homebuilt Systems : New System Build - New build for 1500 help
I am new at building systems, technically this is my first all together build myself. I am looking to buils a system for 1500$. I use a lot of graphics programs like photoshop illustraitor, 3dsmax and my current labtop is starting to slow down. If you could help me by suggesting what components i need for simply the hardware, the OS minitor mouse and everything else I will worry about. So to make it simple and short, I want to build a computer around 1500(a lil overs ok) that has internet, is fast enough to handle graphics programs smoothly and of corse games. thanks!
Sponsored Links
There are a million threads like this.
Just make sure you put more care into assembly than you do in typing.
Reply to Groo
Welcome to the forums!
Case: Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
MoBo: ASUS RAMPAGE FORMULA LGA 775 Intel X48 ATX Intel Motherboard
Video Card: VisionTek Radeon HD4870 (Plan to CrossFire in the future)
PSU: CORSAIR CMPSU-750TX 750W ATX12V
Ram: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
HDD: Seagate Barracuda 7200.11 500GB
Heatsink: Sunbeam CR-CCTF 120mm "Core Contact Freezer" CPU Cooler (Changed from Zalman)
OS: Microsoft Vista Home Premium 64-Bit
CPU: Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor
or
Intel Core 2 Quad Q9550 Yorkfield 2.83GHz 12MB L2 Cache LGA 775 95W Quad-Core Processor
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
- 1 +
That's a good build, but I think I'd change a few things anyway. I'm going to assume that you don't care about overclocking and you do care about games a lot.
Case: Antec Nine Hundred Black Steel ATX Mid Tower Computer Case (or maybe RC-690, cheaper and without bling; good price at www.buy.com)
MoBo: Asus P5Q Pro (save $160 compared to the Rampage Formula)
Video Card: VisionTek Radeon HD4870 X2 (add $290 compared to the HD 4870)
http://www.newegg.com/Product/Prod [...] 6814129114
PSU: CORSAIR CMPSU-750TX 750W ATX12V //again, good price at www.buy.com
Ram: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (save $47 over the DDR2-1066 version)
http://www.newegg.com/Product/Prod [...] 6820231122
Heatsink: none, just get the CPU retail, save $35
or
This build will cost $48 more than evongugg's, or about the same if you go with the RC-690.
It will overclock less well, but it will be better for games thanks to the double video card with extra RAM.
Message edited by aevm on 09-15-2008 at 09:25:57 PM
Reply to aevm
Check out my build, I got almost the exact same parts you got.
http://www.tomshardware.com/forum/255774-31-gaming
Reply to legato89
well seeing as how this is my first build i want to keep it simple. But eventually i would like to do overclocking and anything else i can to make the system run beutifully. I want ot get a solid machine that has the capability to be overclocked and anything else that may be coming out even though i might not be doing it right away. Give it 6 months ill be wanting more you know how it is.
Reply to a13monkey
Also would it be better to get a full case if eventually i would want to be adding more? or will a mid tower be ok.
Reply to a13monkey
- 0 +
All right, let's see. If you're looking for a very high overclock, and money don't matter much, then the Rampage Formula and DDR2-1066 make sense. Also add a Thermalright Ultra-120 Extreme + a SFF21F fan, or a Noctua NH-U12P CPU cooler.
For a good overclock without breaking the bank, the "Core Contact" or the HDT-S1283 coolers are among the best choices, and you can stick with P45 and DDR2-800.
If you get the HD 4870x2 you should pick a case that can fit it. Not sure if it's the world record as size goes, but it's close. Most full towers should be OK, but some mid-towers are roomy enough too. This applies to the fancy CPU coolers too - the best ones are very big.
Message edited by aevm on 09-16-2008 at 02:30:38 AM
Reply to aevm
There are 1277 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
