Tom's Hardware > Forum > Graphic & Displays > Nvidia > Samsung TV HDMI and Geforce 8800GTS problems
Forum Graphic & Displays : Nvidia - Samsung TV HDMI and Geforce 8800GTS problems
I have recently brought a 40" Samsung series 5 TV but seem to be having some odd issues getting it to display properly from my 8800 GTS (640mb OC version)
Initially I used a DVI to vga converter and a standard vga lead to the TV's vga port but found some reason I could not get the TV to accept the native 1920X1080 resolution. It would just say signal not supported. Weird thing is is that it would accept 1920X1200 and most other resolutions. I messed about with custom timings and resfresh rate with no joy.
So I went out and brought a DVI to HDMI cable and plugged it in. The PC picked the TV up as a Samsung device and read all the available resolution correctly. Problem was the TV simply refuses to display any of them. It just repeatedly comes up with "searching for signal" everytime I try any of the supported resoltuons.
Anyone help?
Sponsored Links
I am having the same problems with a Geforce 9500 GS. I plug it in to the samsung on an HDMI cable, and it just flickers on and off. Strangely, this does not happen in the HDMI 3 port on the side of the TV, but then you have to enjoy the hum lines. Any help appreciated.
Reply to Anonymous
There are 1199 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vishnuvamp won the Freshman badge
  • 01:00 whiz won the Freshman badge
  • 01:00 jconline won the Uniformed badge
  • 01:00 qiaoda won the Uniformed badge
  • 01:00 sykohedd won the Uniformed badge
  • 01:00 jundja won the Uniformed badge
  • 01:00 cnsftci won the Uniformed badge
  • 01:00 VistaVendetta won the Uniformed badge
  • 01:00 batuchka won the Uniformed badge
  • 01:00 Nick_C won the Uniformed badge
