Yes No
Ads
Tom's Hardware > Forum > Storage > NAS/RAID > [Solved] RAID 0 speed issue
Forum Storage : NAS/RAID [Solved] RAID 0 speed issue
Best answer from sub mesa.
I got 2 60GB OCZ SSD agility series that I want to use for gaming and running win7 on.
I tested them individually with HD Tune Pro.
Unpartitioned: avg read = 230 MB/s
NTFS partitioned (4KB cluster size): avg read = 205 MB/s
I added both of those in a raid 0 on my rocketraid card.
Raid 0 NTFS (default cluster size): avg read = 150 MB/s
Why is this happening? Do I need to configure them in a certain way?
Thanks for your help.
Message edited by skhope on 02-18-2010 at 03:11:48 PM
Reply to skhope
How did you set up the RAID array? Software- or hardware-based?
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
I have a HighPoint RocketRaid 3120 card. I added both my SSDs on it. I am sorry my computer knowledge is pretty limited, but I think that's a hardware raid. I just followed the default steps to create a raid 0 on it during bootup.
Reply to skhope
Post screenshot here of the Random Access and File Benchmark of HDTune Pro, and we'll have a look to see if your RAID is performing properly.
Reply to sub mesa
Drive 1:
http://i45.tinypic.com/10fz67n.png
http://i49.tinypic.com/4jrllw.png
Drive 2:
http://i46.tinypic.com/2n1vnmg.png
http://i49.tinypic.com/qq3902.png
Raid0:
http://i48.tinypic.com/14uxr3r.png
http://i46.tinypic.com/106c4r6.png
Reply to skhope
Are you really running Windows 7? Looks more like XP to me. With XP you have misaligned partitions that decrease RAID0 performance.
Also, what stripesize did you use to configure the RAID0? You may gain more performance out of software RAID (even with XP or Windows 7) but you would lose boot support, meaning you need to use another system drive to boot from.
Reply to sub mesa
No, I am not running win 7 yet. That's what I would like to do once I have raid properly configured. I have win xp running on a velociraptor.
I had NTFS formatted the SSDs individually for single drive tests. Then when I built the array it removed all partitions and I had to format it again to NTFS.
I am not sure how to check the stripe size for my raid controller. I left everything default when I built the raid array for the SSDs. The only thing I remember seeing during the config was a sector size, which I left to default as well.
Reply to skhope
Best answer
Well right now your RAID sucks. Your performance is lower than a single SSD.
Thats due to two things:
- misalignment due to windows XP
- RAID controller not fast enough
The RAID controller wasnt made to handle SSDs; the SSDs are too fast for the controller to keep up with. You either need software RAID or you should avoid RAID; hardware RAID limits the performance. With software RAID your CPU is alot stronger and can handle many more IOps.
Reply to sub mesa
There are 1581 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Connecting a Laptop Hard disk directly to Desktop (SATA)
By RetiredChief, 6 hours ago:
fantastik250 - Sata interface is only for data. Does not adjust any voltages. power is...
Best offers
