Solved
Hard Drive Clicking but SMART says OK
So this afternoon I ran crystaldiskmark on my Eee PC 1000HE's internal drive... the stats were nice and good until the 4k test, and which point the drive made a clicking noise and the system BSOD'd. It rebooted fine into windows, and I managed to run ChkDsk without it crashing (although it clicked in one spot...) HD Tune's SMART status reader says that those diagonstics are at least reporting the drive is ok.
Is it possible that the drive benchmarker I ran did something to cause physical damage? Or is it possible it messed with a configuration somewhere thats causing this behavior?
I'm about to run Seatools (Since its a Seagate drive.)
Is my drive dying?
Thanks
12 answers Last reply Best Answer
More about hard drive clicking smart
  1. I've had 3 different Seagate drives make clicking sounds and then finally die. They all showed up as being fine in the SMART data. I even had one pass Seatools short drive self test while it was clicking away. However, it failed the long drive self test. Clicking sounds (and especially the bsod) means your hard drive is dieing . Back up your data immediately and RMA the drive.
  2. Still running the long drive selft test, so I'll see what that says. My gut feeling was that it was failing, oh well.
    Is the fact that this came up after I can Crystal Disk Mark a coincidence, or is there some sort of cause and effect going on here (Did I cause it or reveal an existing symptom?)
  3. In the past years I had three drives making a clicking sound. In two cases a faulty power supply was causing the problem.
    A drive benchmarker (or any other prgram for that matter) cannot kill a hard drive.
  4. Unfortunately SMART does not always work. Actually in my experience your ear is a MUCH better tool to use. If you can hear clicks from the drive then i suggest you backup your data and get ready to replace it...
  5. The Seagate tool's long drive test indicated a failure. Fortunately its only a netbook drive so all my data was already backed up!
    Whats confusing me is that I only started hearing the sound after the benchmarker ran. Is it possible that wrote to some sectors I'd never written to otherwise?
    Mimoso- Were there any other symptoms of the power supply having problems?
    Thanks for the responses!
  6. Best answer
    All the benchmarks stress the component under test. That is why you will see in most of them that there is a disclaimer saying that running this utility might break down something in your computer and that they do not have any liabilities if it happens so. On the other hand if you only ran a simple benchmark and it broke down, then i think it is a good thing because now you know that this hard drive is not reliable and you will not use it for anything serious. Running a benchmark a few times to see how your hardware performs is no big deal and it SHOULD return normal results. If something breaks down during a couple of sessions then to me it was not worth having it in the first place in my computer. On the other hand, running benchmarks constantly is like revving your engine all the time=you will probably come across a failure much quicker than normal.
  7. Best answer selected by duckedtapedemon.
  8. Thanks guys, you confirmed by gut feeling as well as my take on this simply revealing an underlying problem...
    Dunno if I'll be able to RMA it but I'll at least replace it BEFORE it explodes.
  9. hey! i have a seagate hard drive that doesn't click all the time... only when it's at rest and i try to access a file on it! so basically when i click open a file on the drive when it's at rest, the waiting sign for my pointer comes up and nothing will happen for 2-5 seconds then finally, !CLICK! (overexagerated... not too loud... but you can't miss it =/ ) then after the click the file opens normally... i understand the clicking sound is normal apparently for seagate hard drives... but im worried about the late response! =( please help? Thanks!
    That is normal. Actually the OS is putting the hard drive to "sleep", so it spins down. That means it conserves more energy and is obviously more quiet because it is not spinning any more. That happens when there is no access to the drive for some time. That is why as soon as you try to access something off that drive the system takes a few seconds to "wake up" the drive. Hence that small pause that you experience and then that "click" (hard drive waking up) and then everything works fine. As long as you access anything off that drive it will not spin down and therefore no more pauses. It is normal and there is nothing to worry about. If you want to get rid of the pauses you will have to access the power saving settings of your OS and set the sleep time for the hard drives to something longer or completely disable it if you get really annoyed. Otherwise nothing to worry about. :)
    I have this disk (see below) .... seems all ok but its clicking noise is not possible to miss it.
    I removed Intel Matrix Storage because someone suggest me that could be the cause. But the noise still remains.
    So... I dont' know what can I verify...do,...test.
    What do you suggest me!
    (I already made a backup)
    Dell E6500.
    Main disc OS : SSD
    HDD (with click noise) : HDD WD...se below, into the module bay (ex slot of DVD) using this:
    http://www.amazon.com/9-5mm-DRIVE-caddy-Latitude-E6400/dp/B004X56K8E
    HDD HARD DRIVE caddy for Dell Latitude E6500
    Thank you a lot!
    CrystalDiskInfo 6.3.0 (C) 2008-2015 hiyohiyo
    Crystal Dew World : http://crystalmark.info/
    OS : Windows 7 Professional SP1 [6.1 Build 7601] (x64)
    Date : 2015/03/31 22:06:02
    -- Controller Map ----------------------------------------------------------
    - Ricoh MMC Host Controller [ATA]
    + Intel(R) ICH9M-E/M SATA AHCI Controller [ATA]
    - Crucial_CT128M550SSD1
    - WDC WD7500BPKT-00PK4T0
    + Controller standard PCI IDE [ATA]
    - ATA Channel 0 (0)
    - ATA Channel 1 (1)
    -- Disk List ---------------------------------------------------------------
    (1) Crucial_CT128M550SSD1 : 128,0 GB [0/0/0, pd1] - mi
    (2) WDC WD7500BPKT-00PK4T0 : 750,1 GB [1/0/1, pd1] - wd
    Model : Crucial_CT128M550SSD1
    Firmware : MU01
    Serial Number : ************
    Disk Size : 128,0 GB (8,4/128,0/128,0/128,0)
    Buffer Size : Unknown
    Queue Depth : 32
    # of Sectors : 250069680
    Rotation Rate : ---- (SSD)
    Interface : Serial ATA
    Major Version : ACS-2
    Minor Version : ATA8-ACS version 6
    Transfer Mode : SATA/300 | SATA/600
    Power On Hours : 105 hours
    Power On Count : 157 count
    Host Writes : 365 GB
    Wear Level Count : 3
    Temperature : 38 C (100 F)
    Health Status : Good (100 %)
    Features : S.M.A.R.T., APM, 48bit LBA, NCQ, TRIM, DevSleep
    APM Level : 00FEh [ON]
    AAM Level : ----
    -- S.M.A.R.T. --------------------------------------------------------------
    ID Cur Wor Thr RawValues(6) Attribute Name
    01 100 100 __0 000000000000 Raw Read Error Rate
    05 100 100 __0 000000000000 Reallocated Sectors Count
    09 100 100 __0 000000000069 Power-On Hours
    0C 100 100 __0 00000000009D Power Cycle Count
    AB 100 100 __0 000000000000 Program Fail Count
    AC 100 100 __0 000000000000 Erase Fail Count
    AD 100 100 __0 000000000003 Average Block-Erase Count
    AE 100 100 __0 000000000031 Unexpected Power Loss Count
    B4 __0 __0 __0 00000000040C Unused Reserve NAND Blocks
    B7 100 100 __0 000000000000 SATA Interface Downshift
    B8 100 100 __0 000000000000 Error Correction Count
    BB 100 100 __0 000000000000 Reported Uncorrectable Errors
    C2 _62 _49 __0 003300110026 Temperature
    C4 100 100 __0 000000000010 Reallocation Event Count
    C5 100 100 __0 000000000000 Current Pending Sector Count
    C6 100 100 __0 000000000000 Smart Off-line Scan Uncorrectable Error Count
    C7 100 100 __0 000000000000 Ultra DMA CRC Error Rate
    CA 100 100 __0 000000000000 Percent Lifetime Used
    CE 100 100 __0 000000000000 Write Error Rate
    D2 100 100 __0 000000000000 Successful RAIN Recovery Count
    F6 100 100 __0 00002DB8C347 Total Host Sector Writes
    F7 100 100 __0 0000016E8F06 Host Program Page Count
    F8 100 100 __0 0000008C2E19 Background Program Page Count
    -- IDENTIFY_DEVICE ---------------------------------------------------------
    0 1 2 3 4 5 6 7 8 9
    000: 0440 3FFF C837 0010 0000 0000 003F 0000 0000 0000
    010: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 3345
    020: 0000 0000 0000 4D55 3031 2020 2020 4372 7563 6961
    030: 6C5F 4354 3132 384D 3535 3053 5344 3120 2020 2020
    040: 2020 2020 2020 2020 2020 2020 2020 8010 4001 2F00
    050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB B110
    060: C2B0 0EE7 0000 0007 0003 0078 0078 0078 0078 40B0
    070: 0000 0000 0000 0000 0000 001F 950E 00C4 016C 004C
    080: 03F8 0028 746B 7D09 6163 7469 BC09 6163 407F 0001
    090: 0001 00FE FFFE 0000 0000 0000 0000 0000 0000 0000
    100: C2B0 0EE7 0000 0000 0000 0008 6003 0000 500A 0751
    110: 0C1C 463E 0000 0000 0000 0000 0000 0000 0000 401E
    120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 4D55
    130: 3031 2E30 4E2E 5330 0000 0000 0000 3233 3535 2020
    140: 2020 3030 5835 3231 3837 2020 2020 4D54 4644 4441
    150: 4B31 3238 4D41 5920 0000 0000 0000 0000 0001 0000
    160: 0000 0000 0000 0000 0000 0000 0000 0000 0003 0001
    170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    200: 0000 0000 0000 0000 0000 0000 0035 0000 0000 4000
    210: 0000 0000 0000 0001 0000 0000 0000 0001 0000 0000
    220: 0000 0000 107F 0000 0000 0000 0000 0000 0000 0000
    230: 0000 0000 0000 0000 0001 00FF 0000 0000 0000 0000
    240: 0000 0000 0000 4000 0000 0000 0000 0000 0000 0000
    250: 0000 0000 0000 0000 0000 47A5
    -- SMART_READ_DATA ---------------------------------------------------------
    +0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
    000: 10 00 01 2F 00 64 64 00 00 00 00 00 00 00 05 33
    010: 00 64 64 00 00 00 00 00 00 00 09 32 00 64 64 69
    020: 00 00 00 00 00 00 0C 32 00 64 64 9D 00 00 00 00
    030: 00 00 AB 32 00 64 64 00 00 00 00 00 00 00 AC 32
    040: 00 64 64 00 00 00 00 00 00 00 AD 32 00 64 64 03
    050: 00 00 00 00 00 00 AE 32 00 64 64 31 00 00 00 00
    060: 00 00 B4 33 00 00 00 0C 04 00 00 00 00 00 B7 32
    070: 00 64 64 00 00 00 00 00 00 00 B8 32 00 64 64 00
    080: 00 00 00 00 00 00 BB 32 00 64 64 00 00 00 00 00
    090: 00 00 C2 22 00 3E 31 26 00 11 00 33 00 00 C4 32
    0A0: 00 64 64 10 00 00 00 00 00 00 C5 32 00 64 64 00
    0B0: 00 00 00 00 00 00 C6 30 00 64 64 00 00 00 00 00
    0C0: 00 00 C7 32 00 64 64 00 00 00 00 00 00 00 CA 31
    0D0: 00 64 64 00 00 00 00 00 00 00 CE 0E 00 64 64 00
    0E0: 00 00 00 00 00 00 D2 32 00 64 64 00 00 00 00 00
    0F0: 00 00 F6 32 00 64 64 47 C3 B8 2D 00 00 00 F7 32
    100: 00 64 64 06 8F 6E 01 00 00 00 F8 32 00 64 64 19
    110: 2E 8C 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    160: 00 00 00 00 00 00 00 00 00 00 80 00 53 02 00 7B
    170: 03 00 01 00 02 03 03 00 00 00 00 00 00 00 00 00
    180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1B
    -- SMART_READ_THRESHOLD ----------------------------------------------------
    000: 10 00 01 00 00 00 00 00 00 00 00 00 00 00 05 00
    010: 00 00 00 00 00 00 00 00 00 00 09 00 00 00 00 00
    020: 00 00 00 00 00 00 0C 00 00 00 00 00 00 00 00 00
    030: 00 00 AB 00 00 00 00 00 00 00 00 00 00 00 AC 00
    040: 00 00 00 00 00 00 00 00 00 00 AD 00 00 00 00 00
    050: 00 00 00 00 00 00 AE 00 00 00 00 00 00 00 00 00
    060: 00 00 B4 00 00 00 00 00 00 00 00 00 00 00 B7 00
    070: 00 00 00 00 00 00 00 00 00 00 B8 00 00 00 00 00
    080: 00 00 00 00 00 00 BB 00 00 00 00 00 00 00 00 00
    090: 00 00 C2 00 00 00 00 00 00 00 00 00 00 00 C4 00
    0A0: 00 00 00 00 00 00 00 00 00 00 C5 00 00 00 00 00
    0B0: 00 00 00 00 00 00 C6 00 00 00 00 00 00 00 00 00
    0C0: 00 00 C7 00 00 00 00 00 00 00 00 00 00 00 CA 00
    0D0: 00 00 00 00 00 00 00 00 00 00 CE 00 00 00 00 00
    0E0: 00 00 00 00 00 00 D2 00 00 00 00 00 00 00 00 00
    0F0: 00 00 F6 00 00 00 00 00 00 00 00 00 00 00 F7 00
    100: 00 00 00 00 00 00 00 00 00 00 F8 00 00 00 00 00
    110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E
    Model : WDC WD7500BPKT-00PK4T0
    Firmware : 01.01A01
    Serial Number : ***************
    Disk Size : 750,1 GB (8,4/137,4/750,1/750,1)
    Buffer Size : 16384 KB
    Queue Depth : 32
    # of Sectors : 1465149168
    Rotation Rate : 7200 RPM
    Major Version : ATA8-ACS
    Minor Version : ----
    Transfer Mode : ---- | SATA/300
    Power On Hours : 5081 hours
    Power On Count : 1722 count
    Temperature : 41 C (105 F)
    APM Level : 0080h [ON]
    AAM Level : ----
    01 200 200 _51 000000000000 Read Error Rate
    03 196 172 _21 0000000004A7 Spin-Up Time
    04 _99 _99 __0 0000000006CC Start/Stop Count
    05 200 200 140 000000000000 Reallocated Sectors Count
    07 200 200 __0 000000000000 Seek Error Rate
    09 _94 _94 __0 0000000013D9 Power-On Hours
    0A 100 100 __0 000000000000 Spin Retry Count
    0B 100 100 __0 000000000000 Recalibration Retries
    0C _99 _99 __0 0000000006BA Power Cycle Count
    C0 200 200 __0 000000000032 Power-off Retract Count
    C1 193 193 __0 000000005862 Load/Unload Cycle Count
    C2 106 _95 __0 000000000029 Temperature
    C4 200 200 __0 000000000000 Reallocation Event Count
    C5 200 200 __0 000000000000 Current Pending Sector Count
    C6 100 253 __0 000000000000 Uncorrectable Sector Count
    C7 200 200 __0 000000000000 UltraDMA CRC Error Count
    C8 100 253 __0 000000000000 Write Error Rate
    0 1 2 3 4 5 6 7 8 9
    000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
    010: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 3637
    020: 0000 8000 0032 3031 2E30 3141 3031 5744 4320 5744
    030: 3735 3030 4250 4B54 2D30 3050 4B34 5430 2020 2020
    040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00
    050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB 0110
    060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000
    070: 0000 0000 0000 0000 0000 001F 1F06 0000 004C 0044
    080: 01FE 0000 746B 7D09 6123 7469 BC09 6123 407F 003E
    090: 003E 0080 FFFE 0000 0000 0000 0000 0000 0000 0000
    100: 66F0 5754 0000 0000 0000 0000 6003 0000 5001 4EE6
    110: 57DD C521 0000 0000 0000 0000 0000 0000 0000 4018
    120: 4018 0000 0000 0000 0000 0000 0000 0000 0029 0000
    130: 0000 0000 0000 16FE 013E 0000 0000 0000 0000 0000
    140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000
    150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    200: 0000 0000 0000 0000 0000 0000 7035 0000 0000 4000
    210: 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000
    220: 0000 0000 101E 0000 0000 0000 0000 0000 0000 0000
    230: 0000 0000 0000 0000 0001 1000 0000 0000 0000 0000
    240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
    250: 0000 0000 0000 0000 0000 0EA5
    000: 10 00 01 2F 00 C8 C8 00 00 00 00 00 00 00 03 27
    010: 00 C4 AC A7 04 00 00 00 00 00 04 32 00 63 63 CC
    020: 06 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00
    030: 00 00 07 2E 00 C8 C8 00 00 00 00 00 00 00 09 32
    040: 00 5E 5E D9 13 00 00 00 00 00 0A 32 00 64 64 00
    050: 00 00 00 00 00 00 0B 32 00 64 64 00 00 00 00 00
    060: 00 00 0C 32 00 63 63 BA 06 00 00 00 00 00 C0 32
    070: 00 C8 C8 32 00 00 00 00 00 00 C1 32 00 C1 C1 62
    080: 58 00 00 00 00 00 C2 22 00 6A 5F 29 00 00 00 00
    090: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 32
    0A0: 00 C8 C8 00 00 00 00 00 00 00 C6 30 00 64 FD 00
    0B0: 00 00 00 00 00 00 C7 32 00 C8 C8 00 00 00 00 00
    0C0: 00 00 C8 08 00 64 FD 00 00 00 00 00 00 00 00 00
    0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    160: 00 00 00 00 00 00 00 00 00 00 00 00 0C 30 01 7B
    170: 03 00 01 00 02 7A 05 00 00 00 00 00 00 00 00 00
    180: 00 00 01 04 00 00 00 00 00 00 00 00 00 00 00 00
    1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C7
    000: 10 00 01 33 C8 C8 C8 C8 00 00 00 00 00 00 03 15
    010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
    020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00
    030: 00 00 07 00 C8 C8 C8 C8 00 00 00 00 00 00 09 00
    040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00
    050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00
    060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C0 00
    070: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00
    080: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00
    090: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00
    0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00
    0B0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
    0C0: 00 00 C8 00 00 00 00 00 00 00 00 00 00 00 00 00
    1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7D
  12. @visert, your SMART data look good. If the drive is making a single click during a period of inactivity, then perhaps you are hearing the heads unloading after an idle timeout.
Hard Drives Storage
