Hi,
Having problems with my newly-assembled computer. When I turn the power supply on the two lights on the motherboard light up. And when I turn on the power switch all the fans start to turn and then stop. No beeps at all from speaker. Motherboard lights stay lit. If I push the power switch again nothing at all happens. If I unplug the power supply and then try again the fans will start to spin up. I also noticed after opening up the case and trying to turn on the power using the motherboard power button that there was also a bright flash of light that looked like it was coming from ICH1OR chipset.
Have checked all power connections many times. Everything appears to be hooked up properly. Have tried resetting the memory. Unplugging everything except the video card. Also did the paperclip test on the PSU and it seems to be working ok.
At this point only have 1 sata hard drive and one sata dvd drive and the video card installed on system.
System specs:
Asus P6T Deluxe
Corsair 6 gig memory
Asus ENGTX280 PCIE video card
Corsair HX 1000W PSU
Cooler Master HAF Case
This is the first system I’ve built in over 5 years, so I got the pre-built and tested motherboard bundle with processor from Mwave. Put the rest of it together myself.
Since the power supply appears to be working I assume it must be something with the motherboard. Any suggestions as to what I may be overlooking here would be appreciated.
Thanks,
Hal
System specs:
Asus P6T Deluxe
Thanks,
Hal
