Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Can't change fan speed on my asus 9600 gt please help
Forum Graphic & Displays : Graphics Cards - Can't change fan speed on my asus 9600 gt please help
I have an Asus EN9600GT/TOP graphics card with the glaciator fansink and it runs way too hot. It idles at about 46c and can hit 80c when overclocked playing crysis. I am not sure if 80c is acceptable or not, but I have noticed a considerable decrease in performance when it goes over 70. From everything I have read, I believe that the fan is set at a very low speed. I want to set it to run at 90-100% but I can't change the fan speed with Ntune or Rivatuner. The options are grayed out. I have downloaded NIBITor V4.6 but I am unsure how to use it. I try to use the utility to detect my card's bios but it doesn't work and I have no idea how to access my card's bios. All I want to do is change the fan speed I will do all of my overclocking with software. By the way I have great airflow in my case (3 80mm fans, and I don't care about the noise the fan will make.
This is a pre-built Acer Aspire that i purchased before I knew how to build my own.
Nforce 630i/gforce 7100
E2220 2.4ghz pentium dual core no OC (PRE-BUILT COMPUTERS SUCK)
Asus EN9600GT/TOP video card OC'd to 755 core,1897 shader,2100 memory
Antec true power trio 550w ps with a total output of 36A
Vista home premium 32bit
Sponsored Links
There are 553 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
  • 01:00 dpnaugle won the Freshman badge
